Question about Vextra Cat5e (V6C5E)
A/V cable for Vextra Photo Frame
I need an A/V cable to connect from my Vextra Photo frame to tne TV set. The manual says it is a 1/8" mini plug on the frame end and RCA plugs on the TV end.
  • 16 Answers
Marvw50,
They mean one of these:
http://www.uuzip.com/6-Ft--Shielded-Cable--1-8--Plug-to-RCA-Plug_product_3897551.html
Very inexpensive...if you dont want to wait, im sure your local Radio Shack type store would have one in stock...but at a much higher cost :-)
Hope this helped,
Jem
Posted on Jan 04, 2009
How do I get my sylvania 10 in. Photo frame video intensity increased
Image Settings; Calendar Settings - Sylvania SDPF751B ...
www.manualslib.com > ... > SDPF751B > User manual
Sylvania digital photo frame user manual. Hide thumbs. 1 · 2 · 3 · 4 · 5 · 6 · 7 · 8 · 9 ·10 ... You can decrease/increase the value by pressing. Time: Press to set Date, time. ... Digital Photo Frame Sylvania SDPF733 User Manual. Sylvania digital ...
Electronics - Sylvania
Dec 10, 2015 | Sylvania Cameras
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How do I export pictures from my computer to my digital photo frame?
The digital photo frame should connect via a cable to your PC where it will be seen as another location such as G:\ drive- using Explorer you can drag 'n drop pictures from your PC to the digital photo frame.
When you first plug it in it may have installed software or prompted Windows to download the correct software. If it did then use this application to move pictures to the digital photo frame.
Good luck.
Jul 08, 2011 | Computers & Internet
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
Hello: I'm looking for a manual for a Philips Photo Frame viewer.7FF1CWO. Can't get it to load from our computer. Ross
Hello
You will be able to download the manual at the link below.
Click HERE to navigate to the download page.
Kind regards
Andrea
Aug 14, 2010 | Office Equipment & Supplies
I received a digital photo frame, but no instructions. Where can
I guess I will return the digital photo frame. I do not feel that I should have to pay to get instructions for a digital item. This is ridiculous! Too much greed in the world. Why wouldn't this gift have the manual included ?
Dec 30, 2009 | Vextra Computers & Internet
How to send photos from laptop to digital photo frame
The photo frame will either have a card slot or a USB connection on it. If it has a card slot you will need to connect the card to your compuer first (through a card reader) and download the pictures onto it. Then put the card into the photo frame.
If it has a USB connection, you can use a usb flash drive - first plugged into your computer to download the pictures then plugged into the photo frame.
It is also possible that the photo frame has internal memory - in which case you would connect the frame to your computer directly using a USB cable. It would them show as a "Removable Disk" and you can download directly to it.
Nov 04, 2009 | Office Equipment & Supplies
I have just bought a car with an overhead tv i dont know how to get power to it
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model carmag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Sep 10, 2009 | Necvox Car Audio & Video
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
How to set clock
look on the back of the clock for the company that built it and the model number, look up the company on google and find support, then search for the model number and download the manual or get the phone number and call them. the first one almost always works
Aug 16, 2008 | Vextra Computers & Internet
Vextra Cat5e (V6C5E) Logo
148 people viewed this question
Top Vextra Computers & Internet Experts
David Payne
David Payne
Are you a Vextra Computer and Internet Expert? Answer questions, earn points and help others
