When i plug my headphones into my gateway dx only one side of the headphones works
  • 4,338 Answers
Try your headphones on another radio/receiver to check and see if it is the headphones that is bad. Usually, this happens when a wire comes loose on the headphones.
If the headphones works, then go to Control Panel >Sound and Audio Devices > On the first page, click the advance button > Along the top you will see Wave,Line in etc. Make sure that the balance is set in the middle, esp.on wave and line in.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 16, 2008
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
DX4300-05 How to open Gateway panels
1) Jaws of Life.
2) Acetylene torch
OH, I'M JUST KIDDIN'!
Gateway Support > DX4300 series of Desktop PC > Main Support page,
http://support.gateway.com/us/en/s/desktop/2009/gateway/dx/dx4300/DX4300nv.shtml
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4300/DX4300rv.shtml
Looking at the Front of the computer, is how you determine Right side, and Left side.
The Right side removes with two screws, as far as I can see.
The Left side is a little harder to tell.
Gateway Support is of no help on this one. At least that I have found. Not in User Manual, because it's generic. One size fit's all.
However looking at the Rear View, it looks like the usual style to me.
Hard to make out though, because it's painted Black.
ON the back edge of the Left Side Panel, appears to be a Thumbscrew.
Even with centerline of Power Supply fan.
But there also appears to be a type of flip lock.
Or should state; push over to the inside; a little.
Then using the Fingerpull molded handle on the Left Side Panel, pull the side panel back.
Usually there are Slots in the metal frame, of the computer case.
The side panel has Tabs that stick out, with hooked end.
Along the top, and/or along the bottom.
You pull the side panel back until it stops, then move back forward about an inch, or so. Then bring the side panel straight out.
No?
Then post back what you see, and we'll try to figure it out together.
Post back in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
How do I install gateway GMAX2100 speakers to gateway computer
Hi Angela, first find the green plug and connect it in to your headphone inlet (if you are using a laptop, it usually comes on its right side of, if you are using a desktop, then it could come on its back). Plug each little speaker in to the red and white plugs located at back of the largest box/speaker. Set your speakers control next to you, plug the power cord, turn on your speakers systems, adjust volume at middle turn on your computer... And enjoy it!
Sep 18, 2012 | Gateway GMAX 2100 Computer Speakers
When I plug in headphones the tv, the sound still plays through its speakers and not through the headphones. How do I get the sound to play through the headphones?
Goto tv menu goto OPTION go to output select press the button pick Variable for outter speakers sound for input speakers or headphones.
Feb 04, 2011 | Dynex DX-LCD19-09 19 in. LCD TV
Gateway dx 4820 power up problem
Let's start with some of the basics.
1) Since you were checking connections on the motherboard, was the power unplugged from the computer, AND did you follow Anti-Static precautions?
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit), the hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power, computer case open, computer on a table.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again.
Or use an ESD wrist strap, and connect the alligator clip to the metal frame ]
2) Computer unplugged from power, anti-static precautions followed, remove all ram memory modules, and reinsert them. In fact, it would behoove you to clean the contact pins on the bottom of the ram memory modules, before reinserting them.
Clean with a pencil eraser. Remove the eraser dust, with air pressure from a can of compressed air for computers, or air pressure from your mouth may be sufficient.
You may have bumped the ram memory modules.
Even if they look to be seated, it only takes a few minutes to remove, and reinstall.
After time, corrosion can develop on the gold plated contact pins, at the bottom of the ram memory modules. Doesn't take long to clean them with a pencil eraser.
Handle the ram memory module by the body. The body, is coated with a clear see-through protective plastic.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The above link, is only provided for an illustration of the gold plated contact pins, I am referring to.
It is DDR Sdram ram memory, and has 184 contact pins. 92 on each side.
Your computer uses DDR3 Sdram ram memory.
Has 240 contact pins. 120 on each side, and the Locating Notch is in a different place.
3) Are you sure the 4-pin ATX +12 Volt power cable, is plugged in tightly to the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Processor.
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4820/DX4820nv.shtml
SATA power cable is plugged in tightly to your SATA harddrive?
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
If your SATA harddrive has provisions for plugging in a SATA power cable, and a 4-pin Peripheral power cable, BE SURE that only the SATA power cable is plugged in.
Plugging both in will fry out the harddrive. Maybe not right away, but will down the road.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Reply back in a Comment.
Jul 03, 2010 | Gateway DX4820-01 PC Desktop
No Sound from my Gateway GT5056 Desktop
i think there a problem in your motherboard. send it to a technician.
Apr 14, 2010 | Gateway DX4200-09 PC Desktop
My Gateway laptop says my sound device is working properly, but the sound only works if headphones or speakers are plugged into the jack. how do i fix this?
It sound like your headphone jack is the default sound device. Go to control panel > sounds > look at the devices listed. Click on the speakers that have a device connected to them. You may have two selections for speakers, but one may be tied to a sound device and the other to headphones. Highlight the sound device and click on make this device the default sound device and hit apply.
Nov 15, 2009 | Gateway M305CRV Notebook
My left speaker on my gateway ML3706 laptop just stoped working
If you get sound from both sides of the headphones when you plug it into the same jack the speakers normally plug into all you need to do is replace the speakers. If you mean you plug the headphones into the cd drive that's nothing special. You could have a bad sound card, bad connection in the jack, or bad speakers.
Jun 20, 2009 | Gateway Computers & Internet
No sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Jan 10, 2009 | Dynex DX-LCD37 TV
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
