Question about Eizo I-Station Networking Hub
Can I change my BIOS for another type?
I've got Pheonix V4.0 / 6.0 and it's driven me nuts trying to sort out a boot-up hang and inability to resolve floppy options problem (I've no floppy drive but BIOS seems to think I have and even tho' I disabled all floppy options including controller the system still hangs at boot-up with "Press F1 to continue or press F2 to enter setup", and when it is booted into o/s XP finds a new device (floppy controller) and installs it, but the installation isn't good (floppy is disabled in BIOS remember) and so shows in device manager as "having problems".
I wonder if I can replace this cruddy BIOS with AWARD or something else that might work?
Mobo is Intel Seattle SE440BX.
CPU Type Intel Pentium II, 350 MHz (3.5 x 100)
System BIOS Date 10/05/98
2 Suggested Answers
daverh
  • 117 Answers
SOURCE: Problems with the default settings
I don't know that particular thin client workstation but from the sound of it. it's very similar to others I have worked with. I suspect that some configuration data has got corrupted. There is normally a way to reset the terminal to the factory default - I would suggest you try that & then set it up again. It's a nuisance but I often used to find that was the only way to deal with this kind of problem. To reset it this way: There is often a small button on the back of the device which you keep pressed in whilst powering it on; if not you'll need to check the manual.
Posted on Jan 06, 2008
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Hi guys ... I'm having a problem that's got me pulling my bloody hair out, and I've got absolutely no idea how to solve it. I've got a box with a blank drive in it [so no existing OS...
if you were flasing the bios and it was interrupted you might be **** out of luck if the bios was compltedly erased. the only thing you can do is try flashing the bios again , make sure it is compatible
Jul 06, 2011 | Dell Dimension C521 PC Desktop
I changed my os from windows xp to windows 7...and i am using amd sempron (tm) processor 3400+ 1.80ghz..and 40 g hard disk..then the windows start up wont start normally. pls help!
Try hitting F8 just after your bios splash screen, before it would show the windows logo.
Select, boot in safe mode with networking.
Once you are in windows 7 safe mode, you can install any required drivers. This might prevent it from hanging on the next normal boot.
You can type in the run dialog CMD. This will open a command terminal. Type "SFC /scannow" without the quotes. This will tell windows to verify it's files. Let it complete, then reboot normally. Hopefully the problem will be resolved!
Mar 25, 2011 | Computers & Internet
When booting, the system hangs at Windows XP logo. It does the same when booting (or trying to boot) into safe mode. What could be the problem and how do I resolve it? I tried to use the Windows XP CD to...
You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
should work.
As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
happened to me on my Vaio.
Feb 09, 2011 | Toshiba Portege M700-S7002 Tablet PC
Having a blue screen issue, boots to windows splash screen, then gives blue stop:0x0000007E error with various (0xc0000005,etc) variations after it. have tried to boot with a floppy, no go. will not let me...
Have you tried to boot in Safe mode? Well if not then press F8 as the PC starts and select safe mode. If it works, then select the 'system restore' option which will appear and restore the system to as far back as it worked very well. Your files will be intact. Well if safe mode those not work, then since you cannot change your boot order to boot from CD/DVD, then you would have to take out your hard drive and connect it to another PC and follow this tip of mine: http://www.fixya.com/support/r3766678-booting_bootable_windows_cd_dvd_fresh
All the best.
Jan 14, 2010 | Panasonic Toughbook 29 Touch (P/N...
Booting Problems When Western Dig. USB Hard drive is Connected
Your laptop will be set to "boot from USB first" in the BIOS. Go into the BIOS (F2, F10 or DEL key as stated on startup) and look for the boot order options.
Change it to boot from the internal hard disk first and all will be sorted.
Feb 06, 2009 | Acer Aspire 5100 Notebook
Olivetti model:800 Type 860T notepad 16mb ram P133
try hitting the escape key first during boot up, then it will prompt you to hit F1. that'll get a in!
Oct 17, 2007 | Computers & Internet
Eizo I-Station Networking Hub Logo
524 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
