Question about Dell 1710n Laser Printer
Dell 1720dn toner error
Toner low light blinks continuously >> Put in new toner cartridge & toner low light continues to blink >> unplugged and replugged, light continues to blink. Any suggestions?
  • MaraD Dec 08, 2008
    Dell 1700/1710 Image Drum and new toner Dell, still toner low and flashing replace drum
  • anavasac Jan 13, 2009
    Exactly the same problem. The drum is from Dell.
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Posted on Feb 19, 2009
  • 33 Answers
Are you using remaufactured toners or did you get the dell ones?
Posted on Nov 16, 2008
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
Apr 09, 2014 | Dell 1720dn Laser Printer
The printer toner light is continuously flashing even after putting in a new cartridge
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
Jun 14, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 12, 2011 | Lexmark E260dn Laser Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Dell 1710n Laser Printer Logo
1,900 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
