Question about IBM ThinkPad R50e Notebook
Another device installation is underway...
Hello, I have this laptop, and I?ve used its built-in system restore (IBM access - the blue button) to format and initial all system properties. After it finished formatting and restoring, the Plug & Play feature doesn't work. Also, whenever I tried to run the add hardware it display the error message: "You can install only one device at a time. "Another device installation is underway, when it is finished you can try this wizard again." Restart / safe mode / killing some process won?t help. Any suggestions? What can I do? Please help!! Thanks in advance, Kim
  • Kimi
    Kimi Nov 28, 2006
    Thanks Sandrew for your quick help!
    I will try that and let you know
  • Kimi
    Kimi Nov 28, 2006
    The UPNP feature was disabled, so I enabled it: http://www.bitwiseim.com/wiki/index.php?...
    But it didn't help.
    Also I couldn?t find something wrong with the USB controllers...
    Please let me know if you think of something else..
    10X again,
    Kim
    President:
  • 2,961 Answers
I think maybe in the bios the UPNP feature is possibly dissabled, as may also be the usb controllers in the device manager. For some reason manufacturers tend to dissable the use of PNP and wireless features as factory default, which your notebook will be set at, although why I have no idea!
Posted on Nov 28, 2006
  • andrew pester
    andrew pester Nov 28, 2006
    Ok, go to control panel>administrative tools>Services.
    Look down the list for 'Plug and Play and ensure it's set at Automatic, also further down the list 'Universal Plug and Play Device Host' is set at Manual.
    Give it a go, if still no joy, I'm at a loss unless a board problem.
Go to run then type regedit then ok
go to HKEY_LOCAL_MACHINE/SYSTEM/SETUP, click on setup.
find the FActoryPreinstallinProgress key & double click it.
Chnage the value data to 0.
Note: You should always backup your registry before making any changes!!
Posted on Sep 10, 2009
Factory restore using command prompt
If the partition is gone, a fresh install is your only option. Download and burn an ISO of your OS. Boot from that and choose your options.
Feb 16, 2014 | IBM ThinkPad Computers & Internet
How do I do a system restore on the IBM A31p? The recovery is built in, but I can't figure out how to access it.
Normally, You receive a restore cd when your cd is purchased. It then accesses the restore drive and installs the nessesary drivers.
Feb 28, 2011 | IBM ThinkPad A31 Notebook
I was just on my ibm t43 and it froze so i manually turned it off now it wont turn back on. it acts like it is going to then it pops up a screen that say an problem has been detected
Hello, Meagan.
Sounds like an operating system problem.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Apr 19, 2010 | IBM ThinkPad R40 2722 Notebook
I power the device on and get the 'IBM ThinkPad' logo screen. Nothing happens after that
Since you are getting the IBM Thinkpad Logo it is confirmed that you have no hardware error. All you need to do is restore the operating system. most of the IBM laptop has an inbuilt recovery option. just press the access IBM/ Thinkvantage (blue button) immediately after pressing the power button and follow the screen..
hope this helps.
Apr 06, 2010 | IBM ThinkPad A22p 2629 Notebook
While i was restore my ibm xp to factory restore i had a power outest and can not restore it
you will need repair CD from IBM or press the blue button on the laptop. Else install using Windows CD.
Sep 03, 2009 | IBM ThinkPad T20 2647 Notebook
Blue screen on Thinkpad R51e & cannot be shutdown
what operating system are you using and please be more descriptive regarding "blue screen" is it the notorious microsoft "Blue Screen of Death"? or? when this occurs is the system totally locked? or can you hit ctrl alt del and get the task manager? can you boot into safe mode? if you're using xp and can get to safe mode.. have you attempted to restore to an earlier restore point prior to this issue? if yes and you haven't restore back to before issue occured.
May 20, 2009 | IBM ThinkPad R51 Notebook
Access built in owners manual.
If you just want to disable the wireless lan, you can go to the control panel, network connections, and right-click on the wireless connection icon. Click on "Disable". Re-enable it by going to the same place and click on "Enable".
In order for the "Access IBM" button to work you have to have the software installed. You can tell if it's installed by looking on the start menu under programs
May 12, 2009 | IBM ThinkPad R51 Notebook
Think pad r40/2681(driver prob.i.e. usb/wireless/sound etc.)
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
You need to use a computer that has Internet access to download and transfer the files to your computer.
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Mar 01, 2009 | IBM ThinkPad R40 2681
IBM ThinkPad R50e Notebook Logo
733 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
