Question about HP Pavilion zt1135 Notebook
Zt1135 wont boot
Safe mode hangs on enecbpth.sys
system restore cd wont read
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    ok the system 32 folder in the windows directory is corrupt, have you gone into the bios to cahnge the boot order to the cd drive to boot the recovery cd?
Mode safe start windows
In this case it would be best to perform a system restore.
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps. Thanks
Oct 27, 2013 | Computers & Internet
I get setupupdd.sys on acer t-135 -t-88z
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse
allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing or it might be a hardware problem
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
if it's a hardware problem system restore will not work
hope this helps
Jul 17, 2012 | Computers & Internet
Blue Screen Error driver_irql_not_less_or_equal 0xd1 Caused by xavzts.sys
You might have installed incompatible drivers. Boot the computer into "Safe Mode" by pressing and holding down the F8 right after pressing the power button to turn PC on. Select "Safe Mode" in the Windows Advanced Boot Options". Icons might look bigger or the screen will look different in Safe Mode. Click Start>All Programs>Accessories>System Tools>System Restore. Use System Restore to restore the computer back to a date when the computer is working fine. The computer will restart during the process.
Hope this help. Goodluck!
Mar 26, 2011 | Computers & Internet
Lap top wont work at all says hard drive problem detected and in safe mode. safe mode comes uo in all 4 corners of screen
You mentioned it boot in safe mode, if it's showing the taskbar where the start button is, then do the system restore. Click start/all programs/accessories/system tools/system restore. Select the previous date that the laptop was working fine the laptop will restart by itself once done. If this process does not resolve the issue, do system recovery (reformat) using the recovery disc that came with the laptop.
Mar 14, 2011 | Computers & Internet
I have a sony vgn-fe780g laptop computer. I cannot load windows. The memory test good with windiag. The hardrive tests good. The computer hangs at loading the mup.sys file if when starting in safe mode. I...
Make sure your installation CD is ok by testing it in another system. You can use utilities in programs like Nero to scan the disk and make sure there are no read errors.
Let me know if this is of any use.
Best wishes,
Mar 05, 2010 | Sony VAIO VGN-FE780G Notebook
Dell Windows XP Media Center Edition 2005 hangs during startup after Welcome screen when user account selected and wallpaper displayed. Next step should have been to display ICONs. If booted in Safe Mode...
Windows file (probably mup.sys) damaged or corrupted. Suspect virus may have done this. If it will not boot to safe mode, then your only real option is to carry out a system repair by inserting the O.S. Cd and at the stage where it looks for a previous installation of windows, carry out the repair, (do not repair at the recovery console stage, wait until the prompt to install windows at the stage mentioned above comes up.)
Once you have it (hopefully) running, then download a command line scanner such as DRWEB and run it in safe mode to remove any memory resident viruses that may be present. I also suggest that you disable sys restore prior to running the scanner to be on the safe side. After any infection is removed, re-apply the system restore.
You can also install another hard drive and install windows on that then the old hard drive as slave and scan it from the newly installed drive. That way you can pull off any important files if needed.
Feb 10, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
Acer am 5630-u5202a boots to Microsoft green bar and then goes to a blank screen. Trying to boot off XP CD receives a PCI.sys error. Trying to boot in safe mode - system stops at a crc.sys file load. What...
This may have happened after an update where a driver was updated that microsoft recommended but was the wrong driver   turn off automatically download and install updates   choose your updates wisely   now to fix that driver either try to roll back the driver   if you can figure out which one it was  even if you have to go to safe mode to do it    or try system restore  to locate system restore choose start/help and support  search for system restore
Nov 03, 2009 | Dell Dimension 2350 PC Desktop
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Dell inspiron wont start!
try to boot in safe mode thru boot menu pressing F2 or F8 or F10 when prompted on startup it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
if it doesnt help then try changing RAM
Feb 22, 2009 | Dell Computers & Internet
Slow computer -how to restore a Fujitsu Siemens Amilo Pro v1000
go to safe mode press F8 key to enter in safe mode
and set your sys in system restore point.
Apr 01, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
HP Pavilion zt1135 Notebook Logo
158 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
