Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
DC18RA from 110v to 220v
Hi, I have the same US charger and need to convert it but it looks slightly diffrent inside. The varistor - do you have a better image of the location or reference number on the circuit board..? Is the a circuit digram available..? Many thanks! Svitus
  • Zuluratnik Dec 30, 2008
    I have the same problem. My charger is different than the one in the tutorial. The components are positioned differently and capacitor (condensator) is 1000uF 200V. Do I need larger one or just with a higher voltage? I have some photos of the charger.
    Sniper:
  • 66 Answers
Hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Posted on Jan 10, 2009
  • 3 Answers
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Posted on Nov 17, 2008
Logitech z623 110v burned to 220v what parts need change i need help
You have a direct short in the power board. Replace the speakers.
Mar 26, 2014 | Logitech Z623
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Modifying the DC18RA from 220V to 110V. how?
Really, this is not something that can be changed easily, just buy a 110 charger...
Mar 14, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
I have the Makita DC18ra s charger for 110V. by mistake i insert it to 220and burn the fuse and a components as described on the borad VDR1 01 Do someone knew what is this components thank alon
yes you can fix it i have done 2 charges but white you are in there if you chance the large round capacitor to a 450v one you then can use the charger in 220 v you will have to increase the size of the voltage resistant diode to 240v (the vrd101 part in the charger) or by pass it with a straight bridge then the charger should work in 220v because the rest of the charger is exactly the same the parts will be around $10 ibought the parts from farnell
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Jan 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18v 120volt american charger to be used in australia
Don't go buying more stuff when you can fix the problem yourself without buying any converter. The modification required to do it is very easy and most people wont have any problem following it.
You can go to this webpage where a detailed walkthrough is given (with pictures):
http://www.byggebolig.no/index.php?topic=5572.0
Some of the post are in norwegian but the walkthrough is in english.
Good luck and happy moding :)
P.S.
For those of you that have "blowed up" a makita charger 110v on a 220v, don't throw it away!
If you are lucky you have only blowed up the fuse and the varistor, which are easy to replace, and if you follow up the walkthrough you might even go all the way a mod the charger to 220v.
I know, I have already manage to "save" a blowed up charger.
May 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
735 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
