Question about Camping, Backpacking & Hiking
Cabelas XPG LI flashlight-stays on only 10 seconds after charging
I bought this $130 flashlight in 10-07 and has been used for a total of 10 minutes total since then.It recharges for a total of 20 minutes before showing ''charged'', but then the light will only stay on for a total of 7 to 10 seconds before shutting completely off. As you see, I paid pretty good money hoping for a decent flashlight, and I thought it would be worth it to take it somewhere to be repaired. I live at 64040.Would I take it to Cabela's of Kansas City, KS to get it repaired? Thanks!
    Novelist:
  • 93 Answers
Even though you've had the light for over a year, I would take it back to the Cabela's, get a manager, explain the problem, and see if they will simply exchange it for a new one. They have pretty good customer service, and if it is one of their own products, then I would expect them to stand behind it.
By the way, sounds like the battery is not holding a charge. Before taking it back, try charging it with the car adapter (it should have come with one) in case your AC Charger is bad. May be that your light and battery is fine, and you have a bad charger.
Also, they do still sell the flashlight there.
Cheers
Nick
Posted on Nov 16, 2008
  • 3,037 Answers
Yes, they should be able to repair it themselves or send it in to be repaired or they may even replace it for you. Just be nice to them and they should give you excellent service. Let me know if you have any other questions. One thing you could try is to charge it overnight and see if it shows any difference for time of use as it may just be saying that it is done before it really is.
  • 13,433 Answers
Hey, the battery needs to be replaced most likely. There is a repair service locator on the right ->
have you tried contacting Cabela support for repair service?
http://www.cabelas.com/cabelas/en/templates/community/customerservice/customer-service-home.jsp?cm_re=store*topnav*cs&cmCat=netcon&cm_ven=netcon&cm_cat=Google&cm_pla=Cabelas%20XPG%20LI&cm_ite=netcon&rid=0180101070502
    Genius:
  • 3,422 Answers
Here is the contact no. Kansas City, KS #1-913-328-0322
  • Priya darshan Nov 16, 2008
    That is the contact no. of the retailer for your product.Give them a call and they will tell you the location so that you can get it repaired from them.
    Thank you.
  • 19,396 Answers
Any Cabela authoirized repairer will be able to fix it, including Cabela's of Kansas City. If you tell me your city \I can find the nearest service point contact.
UDS655 monitor is out. Will not recognize AC Or PC. It must be totally discharged and the Lithium battery is gone
If you can not charge device's battery in any standard manner, the only way you have is to try to charge is manually.
Extract battery and check voltage between + an - terminals using some multimeter or just voltmeter device...
Normal Li-Ion (really Li-Polimer!) battery bank have nominal 3.6V to 3.8V and its voltage should be between from 3.2-3.6 to 4.2-4.3V (depending on model's nominal) to work and 2.5V to 4.3V to be on the safe side. All the good original Li-Po batteries have an internal controller board which prevents overheat and overcharge of the battery preventing it from leak, explosion and flaming. It's important and safety related. Also good controllers prevent overdischarge lower then 2.5V and close circuit to prevent later consumption. Closed battery shows 0V on the terminals, while may have remaining voltage on the battery bank itself, allowing to power controller board. Some controller will not close, so voltage may remain to fall tiil 0V, then the battery controller could switch off due to the power loss staying opened or closed to the external world.
Some devices refuse to charge overcharged battery 'slightly pushing' you to buy a new battery or a new whole device for a bunch of bucks, while making user 'guilty' for overdischarging. There should be the way to catch the developers of that devices and 'slightly beat' them with a 'small stick' to prevent future 'misunderstanding'. :)
I don't know which particular voltage is critical for your device nor battery, nor know whether device does correctly trying to charge overdischarged battery. So, while device wouldn't start charging the battery itself, the only way to understand what happened and do the right thing to fix is to check voltage and try to charge the battery manually till the level, device will detect it and fully charge itself.
If your battery shows some voltage higher then 2.5V it seems the device simply do not want to work (charge) in a reasonable manner.
Provide 4-5V power supply to the battery terminals (Check PSU voltage by your multimeter before trying to be on the safe side!). You should be careful and definitely obey polarity requirements, connecting PSU + to the battery + and PSU - to the battery -
Failing to do so may result in battery and/or PSU damage.
You need to hold powered contacts for a 10-20 seconds, then check battery voltage again. It should rise. Repeat procedure (if needed) till the battery voltage will reach 3 - 3.6V. Then install the battery to the device and try to standard full charge in the device. If your device refuses to start charging battery that shows 3.6V it seems to be the device itself failure.
DO NOT TRY TO CHARGE LI-ION/LI-PO BATTERIES WITH PSU RATED HIGHER THEN 5-6V. YOU MAY DAMAGE BATTERY CONTROLLER!
DO NOT TRY TO FULLY CHARGE YOUR LI-ION/LI-PO BATTERIES USING STANDARD 5V+ PSU. THIS MAY LEAD TO THE LEAK AND/OR EXPLOSION DUE TO OVERCHARGE!
Maximum charge voltage is about 4.3V. Charging till 4.4V will most probably will be dangerous and critical at least for battery itself!
Voltage accuracy is critical here so let the device to fully charge battery as designed or use suitable dedicated Li-Ion battery charger.
Some batteries may not start charging due to the internal controller logic, e.g. controller closed for charge or closed due to the power loss when bank is totally overdischarged. There could be some service terminal on the battery covered by sticker. It may lead directly to the bank -, while bank + usually directly connected to the battery +. In this case you can measure voltage and have the full access to the bank directly so may try to directly charge the bank. Anyway you can disassemble the battery and try to check and charge bank directly via bank's own terminals. Be careful while battery disassembly.
7.4V, 10.8V, etc. Li-Ion (Li-Polymer) batteries have a few banks inside, connected as serial to rise the nominal voltage. To charge them you should use suitable 8, 10. etc PSU or dedicated charger or disassemble the battery and charge each bank separately.
Do not short circuit bank terminals strictly obey polarity and strictly avoid damaging bank itself with some sharp tools! (It is NOT easy to damage hard aluminium case) If you have failed with this some way and you battery started to quickly heat and inflate drop it immediately to some heat resisting surface. DO NOT TRY TO DROP DAMAGED LI-ION BATTERY INTO THE WATER, NOR FLOOD IT WITH WATER IN ANY CASE! IT WILL LEAD TO / RISE EXPLOSION AND FLAMING!
Please note, while LI-ION/LI-PO batteries my explode or leak this occurs very rare and the battery (bank) will not explode in your hands unexpectedly unless you will not try to do something especially stupld, like connecting it directly to the 110/220V outlet. It will heat and inflate for a period of time then safety valve may burst. When the battery will exhaust its energy in a few minutes it will start to cool. Bank most probably will be totally damaged, however may remain some capacity. Excessive gas may be deflated through the hole made with a needle (very careful), then hole should be definitely covered by sticker (scotch) to avoid air/gas or water exchange with bank internals. Overdischarged battery may not heat and leak by physics, simply because it has very small energy charge insufficient for heating, unless you will charge it enough.
Think with your brain and make the right things!
Nov 03, 2017 | The Computers & Internet
Why wont my black and decker ultra bright spotlight stay on for more then 10 minutes ?
The batteries are probably no good or your charger is bad. But I say the batteries themselves are bad. All batteries will only last so long. And it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Feb 16, 2015 | SPOT Camping, Backpacking & Hiking
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
My Inova T3 with freshly charged Tenergy RCR123A Li-Ion batteries (3) runs with full light output for about 1-2 minutes and then drops off so that all you see a small round LED disc inside the lens. If you...
I'm not certain that it's the cause in your case, but a low quality battery can definitely lead to this kind of behavior. I took the plunge when buying myself 18650 batteries for a flashlight for use in the security industry, $20ea for the batteries. I'll never buy cheap again.
Nov 02, 2017 | Inova T3 Tactical Flashlight
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Battery and charger not working correctly.
u r charging,but the charging stays for a few minutes,go for a new battery and try
Mar 04, 2010 | Optics
My duracell crank light 3 in 1 is not working properly. I rotated crank handle for about a minute or 2 long,thinking that charging would be enough and led torch will light for few minutes during power cut...
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
Jun 27, 2009 | Duracell Crank Light 3 In 1, 3 Led...
New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
Does it seems like the new battery takes a charge? If not, then as good as Hitachi's are...it sounds like a defective battery to me. Should be able to warranty for you no prob.
If you have a buddy, check it in his charger. Or possibly try a charger in the store if they have a demo.
Dec 07, 2008 | Drills
My camera eats batteries like candy!
Alkaline batteries are a No-No Rechargeable Ni Cads are little better The Best are NiMh Rechargables in the AA cell range or Li-on in the specialist range. Always get for the best.
Jul 10, 2007 | Vivitar ViviCam 8400 Digital Camera
Camping, Backpacking & Hiking Logo
314 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
