Question about Garmin GPS 48 GPS Receiver
Garmin 48 external antenna failure
After many years, the external antenna failed to acquire any signals. The short stubby "portable" antenna works fine. I cleaned the antenna connection to the unit. No difference. I I cut off the original fitting and replaced it with new. No difference. Is the antenna repairable or is a new one necessary. If new is necessary, where can one for such and older gps be found? Thank you...David
  • davidofglory Nov 17, 2008
    Perfecto! I checked the site mentioned, and found one of several options that is said to be compatible with the 48, including the hardware for rail mounting. Cool!
  • 728 Answers
Check the cords of the antenna and make sure they are connected properly to the unit because a cord may have came apart in the years of it's use. You could get a new antenna, but you can buy a new GPS that is better than the one you have for about the same price as a new external antenna.
Posted on Nov 17, 2008
  • 94 Answers
Antenna's are not repairable so you need to purchase a new one. I have already check for a compatible antenna for your Garmin 48. Please visit this site: http://www.gps-home.com/gps-products/BNC-M.aspx
  • 19,396 Answers
Usuallty it is repairable, as there is probably a broken contact to the iextenal antenna.
The antenna wirings must be built again by taking apart the antenna and checking the soldering.
Often is not worth the job, as an external antenna repalacements are not too expensive.
  • Ginko
    Ginko Nov 17, 2008
    The price for an external antenna is about $50/$80, depending if it is passive or active (here is an uk seller for example).
    You can also buy from Garmin shop here, better to call them as it difficult to locate the items.
    The alternative is taking apart the antenna cable , and soldering a new antenna cable that you buy at any circuit shop for $10 or so.
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
Garmin not receiving satellites
hmmm...did you check for the latest firmware, by chance?
Feb 29, 2008 | Garmin StreetPilot 7200 GPS Receiver
I have a Garmin 3600. When I want to use the GPS feature, and I open the antenna, all I get is Acquiring Satellites, but nothing happens (the little indicatior on the bottom shows activity). I thinkthere...
If you can obtain an external antenna from another IQ3600 user it
will plug into the connecter on the top of the unit and bypass the fold out antenna. I had to buy one because the windshield in my Pont Montanna would block the satalite signals. When I plug in the external antenna I do not have to fold out the antenna on the unit.
That will check to see if the unit is recieving and /or if the fold out
wire is broken. The external antenna is not Garmin specific but the
plug on the end is so another gps antenna with the same end plug works.
Aug 16, 2010 | Garmin iQue 3600 GPS Receiver
Garmin 350 not acquiring - solved
This is a common problem. Even though the wire gave you reception, you still have a bad part in your GPS. Please see this link for more detail:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Oct 24, 2009 | Garmin nuvi 350 GPS Receiver
Sirius Stiletto 2 constantly "acquiring signal"
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
May 04, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Not receiving satellite signal.
1st check to see if an external antenna will work.
Aug 21, 2007 | Garmin iQue 3600 GPS Receiver
Having problems acquiring satellites
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Aug 01, 2007 | Garmin nuvi 350 GPS Receiver
Open Questions:
"Upload ...Not Present" message. Nothing else on the screen. I replaced the internal battery last spring used it all summer. Have just checked internal and external batteries and all are fresh 3v internal and new AA four batteries. Upon startup the screen says "Upload" "Not Present" and there is no menu. I have tried hitting Page and Menu, etc. nothing happens. I tried leaving it out and on for 3 hours to see if it would find itself and satellites. I tried connecting to the computer and uploading the internal program the port was not found. Tried this a number of times and a number of ways. I have tried leaving it on to search for 3 hours and have tried to connect to my computer to reinstall the software but that does not work. The internal battery was replaced with a new one last year. I have fresh batteries in the unit. What is the problem? How do I fix it? Thank you. I love this unit and would like to keep it going. I have fixed two others for friends who needed the internal battery fixed. They use it as a backup. I have tried the Auto Locate procedure about 3 times. I have also tried clearing by holding the PAGE + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Also have tried clearing by holding the MARK + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Now I am wondering if this message has to do with an interrupted connection with EasyGPS from last winter. I was uploading waypoints, and thought it had completed and may have turned off and disconnected the plug before an operation was completed in saving waypoints off the Garmin 48. I do not know this for a fact, but that was the last operation I recall doing last fall, before starting the GPS up again on the boat this spring. I have also tried to connect the unit to Easy GPS via the serial port, thinking perhaps it would complete whatever it is trying to do. I have tried uploading routes and downloading routes via EasyGPS send and recieve and it does not seem to work. I wonder now if the interface setting has been reset, by my pressing PAGE+power and Mark + Power earlier. I would not mind that if the menus came up properly, but that is not happening. Is there some other way to kick it out of this mode? I turn it on and there is the message "Upload...Not present" and none of the menu buttons work to get it into the normal startup screen mode..... I've tried Quit, Page, Enter, Goto, Mark, Power (off and on), and none of the get the computer out of this mode and back into the normal menus for startup. I've removed the antennae and checked all the contacts and that seems fine, and reinstalled. Is there some small reboot button inside that I can jumper? I have tried taking the internal battery out and letting it sit for three days and it still does the same thing. Any suggestions would be appreciated
Jul 08, 2010 | Garmin GPS 48 GPS Receiver
See all Garmin GPS 48 GPS Receiver Questions
Garmin GPS 48 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
