Question about Intel Computers & Internet
What kind of memory do i need for a sis 651 motherboard?
I have 3 slots open and one with 512 M
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    yes can you give me the make and model of the motherboard if possible and the boards age
    thanks
    Scholar:
  • 112 Answers
You need pc 2700 ram. Your board only allows for a maximum of 2 gigs though.
Posted on Nov 16, 2008
  • Steve DiPolito
    Steve DiPolito Nov 16, 2008
    Just for clarification, the board might also accept 2100 and 1600 as well. If you post the specs on the board, I can tell you exactly what kind of pc2700. (dram, sdram, rimm or dimm, ddr2, etc)
I want to know about my chipsets, its classification.
your motherboard chipset belongs to sis.
front bus-533mhz
supports ddr ram only 2 gb
expantion slots-1*agp 4x
grafics- sis real 256
ide- 2*ultla dma133
SPECIAL FEATURES- POWER LOSS RESTART,ASUS EZ FLASH,CRASH FREE BIOS
Nov 24, 2010 | ASUS P4SP-MX SiS 651 533MHz FSB DDR333...
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
What are the memory specifications for the Foxconn 661MO3C-6L?
The memory specifications are as follows...
System Memory
Two 184-pin DIMM slots
Supports PC 3200/PC 2700/PC 2100 memory
Supports 128/256/512 Mb technology up to 2GB
Mar 17, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
No sound,please help!!
try to download the sound driver from here  http://74.125.153.132/search?q=cache:http://www.sis.com/products/sis661fx_benefits.htm  . if it fails again then try to install windows xp with sp2 not sp3 ok.
Jun 14, 2009 | Abit SG-80DC Motherboard
Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
May 25, 2009 | SIS741GX-MN Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
How Can I Speed Up My Slow PC?
Go to Trend Micro and run Housecall to check your PC for viruses and spyware.
If it is still slow go to Start and click on My Computer. Right click on your C: drive and choose Properties. Run the Disk Cleanup. When that finishes click on the Tools tab and do a Check Disk and Disk Defrag.
Jun 07, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Geforce 512 agp ddr2
Hi sledgehammur, you're asking if the SiS 651 controller will allow you to run both the on-board integrated AGP4x & the Geforce AGP DDR2 card to function as one. I don't think your SiS controller will allow it to. You'll have to enter bios & change the on-board graphics not to load frist. (Keep in mind the on-board is also an AGP), but the memory is not the same & neither is your system memory which the on-board AGP use's.
You're manual for the board would give you more insite on that issue. My thoughts are you will need to change bios to run from AGP slot on your board & not use the integrated AGP. The good part is your AGP slot will not use you're system memory to run. You're Geforce's memory is faster.
Here is a link to the SiS 651. http://www.sis.com/products/sis651.htm
Enjoy!
If I can be of more service, just ask.
Mike
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
