Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Old Kenmore refrigerator leak
My old and until now very good Kenmore with freezer on top has developed a leak that gathers water under the veggie bins on the bottom floor of the fridge.
My husband and I pull it out from the wall occasionally and vacuum the coils and all the places we can get to back there.
Is there something that might need tightened or since it's inside the unit that it may be a condensation issue?
It takes a couple days to gather about a cup of water.
I'd like to get it fixed rather than replace it.
Thanks,
Dotsy
  • gig1805 Nov 17, 2008
    aborcass,
    You nailed it!
    I pulled the fridge out and there it was. The tube was disconnected!
    Talk about an easy fix.
    Thank you so much
    President:
  • Kenmore Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 17, 2008
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
My top freezer is leaking onto the top of the refrigerator door. The fridge is 3 months old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Maytag Admiral Top-Freezer Refrigerator
Water leaking inside our fridge. kenmore fridge. about 8and a half years old.
There is a drain line that discharges water from the freezer when the defrost cycle kicks in. It will be a plastic tube that runs from the bottom of the freezer to a tray under the fridge. It has come loose or become plugged I always blow air thru the line and make sure it is not loose. You can also get leakage from an ice maker but this problem will usually show up as ice formingin the freezer first. good luck
Aug 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
My kenmore chest freezer is not freezing but it forms ice on the top on a bucket i placed in the bottom
That sounds like it is just barely working. It could be a refrigerant (freon) leak. How old is this freezer? And what model is it?
Jan 06, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking into the refrigerator from the freezer.
you have to defrost the freezer part and drain tube in the freezer,a hair dryer works well,if after you defrost it and freezes again its your defrost timer,make sure its fully defrosted first before buying the defrost timer
Jul 07, 2008 | Kenmore Refrigerators
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
154 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
