Question about HP OfficeJet 6110 All-In-One InkJet Printer
PRINTER SAYS CARRIAGE JAM HP 6110
NO BLOCKS OR JAMS FOUND. WORKED FINE NOT DROPPED OR MOVED. WENT THROUGH TROUBLE SHOOTING FOR JAM GIVEN BY HP. ANY TRICKS OR DO I HAVE TO GIVE UP AND TAKE IN?
I DID THE PARTIAL RESETS AS WELL. THE CARRIAGE MOVES JUST FINE, IT DOES NOT GO TO CENTER WHEN YOU OPEN THE DOOR TO CHECK THE CARTRIDGES BUT IT MOVES FINE. LOST HELP
ANTHONY
  • 2 more comments
  • gjorge7461 Nov 21, 2008
    Just keeps giving me the same error message that the ink carriage is jammed. I tried everything under the sun to no avail. Can anyone suggest something else other than turning it off, moving the carriage, etc.
  • zufarwa Feb 22, 2009
    my printer cartridge doesn't want to even go to the middle anymore...stays off to the right and if I hit enter it moves a little to the left but doesn't want to go back and forth anymore....it was making a loud scratching sound for a few days before this happened...usually at the end of a printing job...
    i have looked for jams, turned it on and off, hit cancel, enter, nothing seems to work. i have had the machine for 5 years and it was working beautifully until now...except the align cartridge wasn't working...
  • themimim Feb 23, 2009
    I have the same problem. I have to lift up the main cover, stare at the carriage where there is no problem. Close the cover and reset it at the "X". It works fine for maybe two print jobs and it does it again.
  • zufarwa Feb 28, 2009
    there is no error code...it just keeps saying, "clear the cartridge jam" after being turned on and off and reset and doing all the trouble shooting hp says to do...it just gives that same message everytime.
  • HP Master
  • 1,879 Answers
One trick I do for that COMMON issue with HP printers (won't stay at the center where you can have access to the cartridges),
Print a page where the content is placed exactly where I want the print head to be.
Then cut the power by unplugging the power cord.
Remember, It's what I do and I am just sharing my "trick".
Posted on Nov 16, 2008
  • 33 Answers
Whats the error code its giving you ???
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Carriage jam message
The "carriage" is the part of the printer that moves the ink-cartridges & print-head mechanism across the page.
If it is 'jammed", then it is not moving when/where the printer is commanding it to move.
Take the printer to a qualified technician, for trouble-shooting.
Jan 19, 2010 | HP Photosmart 2710 All-In-One InkJet...
What's a carriage jam?
The "carriage" moves the print-heads from side-to-side.
A "jam" means that the carriage is NOT moving when/where it should.
Take the printer to a qualified technician for trouble-shooting.
Nov 26, 2009 | HP Photosmart 2610 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I shipped my HP 6110 from England to Canada. The power adaptor accommodates 220 to 110 voltage, so no problem there.It turned on fine. Now the scanner works, but the print cartridges are stuck in home...
Make sure you actually opened the rear door and reseated it even if there's no visible jam.
Make sure the front panel is correctly installed.
Try resetting the printer by turning it off, unplugging the data and power cables for a few minutes, then plugging it back in and turning it on.
If you've tried this and followed the steps given by HP in a search of your model for "Carriage stall resolution", available here
you may have to have a tech take a look at it...
Apr 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Says Door Open. And it's not. Then it says clear
The following link to HP's website will give you step by step instructions on how to resolve the carriage jam issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00310245&lc=en&dlc=en&cc=us&lang=en&rule=29041&product=79477
More information regarding resolving issues on your OfficeJet 6110 can be found through this link:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=79477&lang=en
Apr 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge jam...cartridge will not move to the left...stays right
turn off the printer and manually move the ink cartridges to the position that you can remove the ink cartridge.
turn on the printer without the ink cartridge. The printer will tell you, you need a ink cartridge, open the printer and insert the ink cartridge as described in the manual.
Feb 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110xi -clear carriage jam
LOOK BEHIND THE CARRIAGE IS A SEE THROUGH CALIBRATED RIBBON WHICH NEED TO CLEANED, IF IT DOESN'T WORK THE SENSOR BEHIND THE CARRIAGE MUST BE CLEANED
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
