Question about JVC RX-6042 Receiver
Cutting out... Hello, Recently, the sound from my receiver will cut out randomly, whether I'm watching dvd's, watching cable t.v., etc. If there is any other information that you folks need, let me know. Gratefully, Myk
  • 2 more comments
  • ratchetman68 Nov 16, 2007
    I have the same problem. It could be on the radio, DVD or anything thats conected to it. Some help would be very welcome.
  • Pratt985 Dec 21, 2007
    Same problem as above...
  • vegwagen Mar 06, 2008
    Same Crap here..No Good at all,,, Some Help Please!
  • Kirk Black
    Kirk Black May 14, 2009
    JVC RX-6042 Shuts off after a few seconds...
    Similar problem but different in that it turns on fine and functions fine for about 10 seconds then shuts off. The user manual describes this to be an over voltage problem.
    I found a bad transistor in the power supply circuit that has way over heated and even turned the leads purple. I replaced it with the original JVC part KTC2026/Y/
    Still the same problem and the power supply output is about 13 Volts but I don't have a reference to compare that with and wonder if that's the over or under voltage problem.
    Genius:
  • JVC Master
  • 1,550 Answers
Si usan el aparato por un periodo largo de tiempo puede ser una de las bocinas que este fallando,mas si se corta rapido pueden ser los ICs amplificadores de audio que estan comenzando a dañarse.Espero que les sea de ayuda.
Posted on Apr 05, 2008
The buttons assigning DVD, TV, VCR, etc suddenly changed their assignments. DVD was now TV, VCR was now DVD, etc. I don't think it all happened at once either. Now I can't get sound from the...
There are facilities to CHOOSE the digital assignment. I've seen where extended power loss will randomly lose custom settings. Open the manual.
Jul 07, 2011 | Pioneer VSX-D912 Receiver
When i play my PS3 game the receiver shorts out and shuts off at random points...also does that when watching a movie will just randomly turn off and short out
Hello
Cutting out on the sound is usually a blown IC on the circuit board of the unit itself. This can also result in the player turning off randomly.
Take you receiver to your nearest electronic repair shop, let them replace the blown IC.
This should do the trick.
Kind regards
Andrea
Aug 29, 2010 | Onkyo TX-SR606 Receiver
Humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Sep 13, 2009 | Yamaha HTR-6030 Receiver
Yamaha Receiver sound cuts out with Dolby Digital.
Your problem is related to HDMI technology not the Receiver. HDMI in it's current version 1.3b has worked out 90% of the current problems being reported by HDMI users. it's a problem with HDCP digital copyright protection and the recording industry not wanting us "consumers" to duplicate or record their DVD's. Your receiver and every other receiver with version 1.1,-1.2, & 1.2a just don't cooperate with BluRay and even HD Cable or HD Sat receivers. If you just purchased this receiver recently, return it and get an 09' model or equivalent with 1.3a or 1.3b HDMI technology. If this unit is "un-returnable" then, what needs to happen is you need to run component video and digital audio to the receiver OR Run your HDMI directly to your TV and run a Digital Coaxial to your DVD audio input on the receiver. Depending on how many sources you are running to the TV via HDMI will be limited to the TV's capability (how many HDMI inputs)
Now, if your TV is 50" or smaller, the difference between running HDMI and Component is unmeasurable to the human eye. So, if you have to run component, don't sweat it! just use good cable, ie. Monster, Phoenix, Translucent etc. I do theese installs every day, and I still prefer Component or DVI if available over HDMI. They just haven't proved the reliability to me yet and we're three years in! Hope this helps
Jun 23, 2009 | Yamaha RX-V563 Receiver
Screen is cutting off the sides
That is an ITC008 chassis and the problem you're referring to is called a breathing picture. One fault I am aware of in this chassis/model is the connector Bl103. I have seen a couple where the connector failed and had to be replaced. Could open it up and locate the conntector and see if it's vibration sensitive.
Bill
Apr 26, 2008 | RCA 32V550T 32" TV
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Sound Cutting Out
If you looked for dry connections and found none, there is probably a componet that is intermittant, and these can be tough puppies to troubleshoot, without monitoring the power supply voltages and sittinfg with the unit.
Jan 04, 2007 | Philips LX3000D System
JVC RX-6042 Receiver Logo
443 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
