Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Need to buy a lamp & Ballast
Hi where can I get the best price for a Lamp and Ballast for a Panasonic Model PT 50LC14.
Thanks
  • nrhazi Jan 19, 2009
    where can i find a ballast at a good price for a Panasonic TV PT-50LC14 50 in.
    Thank you
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
My panasonic pt-50lc14 turns off the power light flashes red and temperature light flashes.
Examine the lamp first and be aware the model 50lc13 and 50lc14 which are almost identical had all sorts of problems----the lc13 was part of a massive recall/exchange that cost Panasonic tens of millions of dollars.
could be lamp or even the ballast which was the real issue involved in the recall.
Aug 27, 2012 | Panasonic PT-50LC14 50" Rear Projection...
My panisonic HDTV viva model pt-50lc14-k wont turn on just keeps making a noise
This may mean the lamp or ballast is bad--lamp should be customer replaceable and if taken out can be examined to see if shattered or not.
This and the Pt-50LC13 had all kinds of lamp related issues.
If lamp looks ok have a tech look at it. FYI: if set does not come on one of the lights on front should be lit and or blinking--error being displayed.
Apr 23, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Picture won't come on. light flashes green continually, after 3 or 4 minutes the light flashes red continually. bulb is less than 6 months old. any ideas?
Hi:
This model was notorious for fan failure. The most common failure was the lamp temp fan. Its use to keep the lamp a constant temp. Also if one of the fans fail the unit will not start, This model is also known for Ballast failure also. The ballast is use to light the lamp. The best thing you can do is have a service technician come out and diagnostic the set for a minium fee.
Nov 09, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I am hearing a ticking noise from the thermal fuse when I try to turn on my Panasonic Model # PT-50LC14. Is this a quick fix I can do or will I need to have it repaired?
I've never heard a thermal fuse tick in a set, I think what you are hearing is the ballast, this is normal, have you ever changed the lamp in this set, if not that is probably the problem.
Sep 09, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Lamp
Are you buying the original lamp from Panasonic? If you are, replace the ballast circuit in the TV set. Good Luck
Sep 18, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
598 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
