Question about GE JGB916SEKSS stainless steel Gas Kitchen Range
Self Cleaning Lock locked...
Spilled some stuff in the oven and wanted to run the Self Cleaning... I apparently didn't have the door all the way closed when I hit start and now the latch is locked but the door is still open. Help! There must be a way to open the latch "manually" I tried to cycle the power to the stove. Off 30 seconds at breaker. That didn't even reset the clock... I saw a refence to a manual open? Any help is appreciated... I have warranty support but that takes 2-3 weeks I can't imagine no oven for that long even witht eh toaster oven and microwave working!
  • Anonymous Feb 24, 2008
    My oven door is locked & I tried the unlock directions in the manual & still won't unlock! Help, it's my daughters b-day & trying to bake a cake & cook a b-day dinner!
    Thanks,
    Desperate
  • 1314 Answers
SOURCE: Self-Clean Cycle --- Lock Door Light Flashes
the door lock should be automatic just set everything and push start
Posted on Mar 30, 2008
reg501
  • 413 Answers
SOURCE: Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Posted on Jun 06, 2008
  • 22 Answers
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Posted on Mar 31, 2009
heatman101
  • 43501 Answers
SOURCE: Self-cleaning overn won't turn on
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 28, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Oven lock stuck in locked
Hello there:
This is a very common issue with these appliances whenever the cleaning cycle is interrupted this normally is the result.
So what you will need to do is to first unplug the appliance from the wall outlet and leave it alone for 1 hour this allows the internal self reset feature to reset the oven.
once the hour has elapsed plug it back in and you should hear a audiable click within about 5 min or if you have a cancel button press it and you should be able to continue from there okHopethis is very helpful for you Please keep me posted ok
Best regards mike
Posted on Oct 08, 2010
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When cleaning the stove i touched my accident the
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
When I try to start the self-cleaning oven, ''door'' appears in the display, and then the display goes to F5 E1. The door doesn't even try to lock. I have a Whirlpool Self-cleaning electric range Model #...
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Self-cleaning oven will not start.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
sad
Dec 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
