Question about DeLonghi CAFE DUO Dual Drip Coffee Maker
Control panel lights
After several months of problem free service, the timer and "on" lights on the right hand side of the machine both blink simultaneously. If I press the on button on that side, the machine comes on and brews, the brew light is steady and the timer light goes off. As soon as the cycle is complete, both light start blinking at the same time again. I have lost the manual and don't know if the issue is addressed there or not. Unplugging the machine and plugging it in again does not reset it. Any help?
I tried the On/Off and PROG buttons simultaneously but nothing happened. Then I just guessed and pressed the HOUR and MINUTE buttons simultaneously and it worked. My wife's going to love me for this one (Ha-ha).
Posted on May 12, 2010
The manual indicates this means that it is time to decalcify the machine.  After doing so, press the ON/OFF and PROG buttons at the same time for 2 seconds.   Jeff, Burbank CA
Posted on Oct 13, 2007
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Where is the water filter what is the part number and how do you change it
Hello Dwane;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number of your unit. The water filter location is dependent on the model number. The model number is located on a label on the inside of the fresh food section liner.
You have a bottom freezer. In general the water filter is located in the upper right hand corner of you right side fresh food section.
You may have a screw on the side panel to remove the cover, or some retainer clips, of which you must squeeze the cover housing to remove, or you may have free access.
Once locating, or accessing the water filter, grab the base and turn 1/4 turn clockwise to release and pull down. Insert the new water filter, insert and turn counter wise to the right.
Purge the air out of the filter system. Water filters are dry and have air in them. With your water dispenser fill several cups until al of the air is purged out. There will spiriting sounds.
You replace your water filter when you notice your ice cubes are small & when the water flow from your dispenser is low. The change water indicator light is a timer. It is set to cycle every six months. It is like a egg timer. It is not connected to anything.
Depending on the size of your family, and the usage you may need to change the water filter every six months or every 1-1/2- 2 years.
Nov 08, 2014 | Refrigerators
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Has quit spinning. Not the belt. Possibly the timer. How do I get to the timer and what does it look like?
Remove the top control panel. Chances are, the schematics worksheet with repair tips is there and your timer should be on the right hand side, behind the control panel.
Jul 31, 2011 | Hotpoint VBXR1090D Top Load Washer
Replaced lamp a month ago. tv turns on then shuts off with blinking amber color. i do not have the original remote. What does it mean when blinking amber light comes
don't know what model but with lamps being replace, a few things are important, 1 the right part for your set, 2 not touching with hand, 3 cleaning the area first good, free of dust.
Jan 12, 2011 | Televison & Video
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE washer fills, empties, won't agitate or spin. model whdrr418giww only about 18 months old
you will have to remove the front panel of the washer. then look on top of the motor. on top of the motor is a control board. whille the machine is turned on, you should see a flashing light located in the middle of the control board to the right. you will have to count how many time that light blinks.
once you have a count, gain access into the control console(where the timer is) by removing a few screws. in there you will find a tech sheet that will tell you what the blink count means. i bet you its the motor thats bad. its about $160.00
if you need to order a part goto http://lartoday.com/order_parts.htm
good luck
Levi
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 10, 2009 | GE Washing Machines
Cant find self timer
On the back of the camera is a button near the right hand side ogf the LCD screen - this is the self timer button. Use the control dial to set it for 12sec or 2sec.
1 Press the shutter button all the way.
A picture is taken.
The focus and exposure are locked when
the shutter button is pressed halfway.
• When Y12S is selected: First, the selftimer
lamp lights up for approximately 10
seconds, then it blinks for approximately 2
seconds and the picture is taken.
When Y2S is selected: The self-timer lamp
lights up for approximately 2 seconds, then
To cancel the activated self-timer, press the button again.
Aug 20, 2008 | Olympus Cameras
DeLonghi CAFE DUO Dual Drip Coffee Maker Logo
483 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
