Loud bang from speakers
When I lift LP record off the TT, a very loud sound (60-100 Hz) comesout of speakers. So I always reduce the volume considerably to changethe record. The tonearm wire is properly grounded to the phono preampground terminal. I also tried to ground the chassis by connecting awire from tonearm base to ground receptacle of AC plug. All failed tosolve the problem. I think it is a static induced problem. The worst part is there is a very loud pop once in awhile during the play especially in winter. The humidity in the room is60 - 65%. I'd appreciate your suggestion.
  • djkiwi Nov 18, 2008
    Same issue here!
I would suggest that you check the condition of the stylus, because the sound could be prouduced when the needle is lifted and the diamond tip is damaged so it makes a loud noise, normally a loud crack.
Posted on Jan 26, 2011
When I plug in my marantz TT-42 turntable to my Yamaha R-S300 receiver's phono input, I get a muddy and loud sound. I've tested the turntable with direct input to Bose speakers and it works fine.
If the turntable produces good sound with a line level input on another system, you have the turntable with the pre amp built in. That is why the sound is loud and distorted.
Mar 05, 2017 | Yamaha Audio Players & Recorders
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
My RX-V567 (about 3 months old) has some problem with the sound output. Sometimes when it is turned on, it gets very loud even though the volume is set at around -48 db. And when I turn down the volume, it...
Your volume control is not tracking properly. Might want to clean out the control chemically.
Check the surround on the subwoofer speaker. If it has self destructed the surround needs to be replaced.
Sep 03, 2017 | Yamaha RXV567 Receiver
How do i get my speaker to stop making loud sounds
Reduce the volume for sure, but if what you meant is some crackling noise then the power amplifier must be checked for malfunction. The failure can be a series of failures on the power amplifier , disconnect the input and confirm that it is an internal noise and not from any source.
Jan 21, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
under voice recording clk volume and mute the mic phone...........
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Loud blowing noise from turbo when accellerating
Check the clamps aound the Inlet and Exhaust sides of the Turbo, and the Rubber Boots that connect the High pressure Air flow to the Charge Cooler Inlet and Outlet sides and the Boot into the Manifold. Any of these defects will create this sound. Especially look for a Split in the Connecting Boots, which will reduce Intake Air Pressure and Volume, which indicates a fault to the ECM, and susequent warning.
Aug 30, 2009 | 2001 Audi TT
50Hz noise appears at the end of the disc
Nov 16, 2008 | Philips gemini XL-500 II Turntable
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
223 people viewed this question
