Solution
SOURCE: My scanner error message
Whatever the error message you get, write it down and Google it, you will always find the solution. It has never failed for me. But be carefull some solutions could end up costing you.
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: When sending document to my
When sending document to my HP LaserJet P1505, the engine scanner error message
