Acer Aspire One AOD250-1326 Netbook Logo
Anonymous Posted on Apr 24, 2012
Where is buy a batterie for laptop look at a site www.elecachat.fr
Batterie et Chargeur adaptateur pour PC Ordinateur Portable,Caméscope, Appareil Elecachat.fr vour propose un catalogue en ligne de batteries, chargeurs, adaptateur et alimentations secteur pour pc ordinateur portable, caméscope, appareil photo ... http://www.elecachat.fr/
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Apr 25, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059898
Points
15385
The best place to buy a battery for your laptop is eBay. Once the site comes up just put in the search box something like Acer Aspire One battery. Click the link below and type in the search box "Acer Aspire One Netbook Battery" (without the quotes) and click Search. When the search results come back Select to only see the Buy It Now merchandise and Sort the list by lowest price first. The first couple of items will be ac adapter and power cord, but once you hit the prices in the $20 range you will start seeing the battery. Click the link below
to see a all the batteries.
http://www.ebay.com
The link below will take you directly to one that I selected that costs $23.99 including FREE Shipping. Please note that the battery fits the Acer Aspire One ZG5, A110, A150, D150 and the D250 which is your model.
http://www.ebay.com/itm/New-Netbook-Battery-for-ACER-ASPIRE-ONE-ZG5-A110-A150-5po-/250979671222?pt=Laptop_Batteries&hash=item3a6f8ddcb6
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Aug 22, 2009
SOURCE: curseur fou dan une emachine 520
Bonjour,
Je ne connais pas cette machine, mais il se peut que par inadvertance tu aies changé la vitesse du curseur.
Dans les machines Windows, clique démarrer, panneau ou tableau de contrôle. Cherche l' icône de la souris et clique dessus. Sous l'onglet Option du curseur (Pointer Options), tu pourras régler la vitesse de ton curseur.
J'espère que cela t'aidera.
Falla de convergencias en tv panasonic presenta una franja morada den nado izquierdo parte inferior
batterie Acer TravelMate 7530, 4400mAh 6 cellsbatterie Acer TravelMate 7530 Ordinateur Portable
Type de priphrique : Batterie de Portable
Capacit :4400mAh
Tension : 11.1V
Chimie : Li-ion
Couleur : Gris
Disponibilit:Tous Les Modles En Stock
Prix:
EUR 80,99
Spcial
EUR 72,99
http://www.elecachat.fr/acer-travelmate-7530-series.html
1helpful
Bonjour comment l'activer pour pouvoir enregistrer le disc dur de mon portable merci
Bonjour Arnaud,
ce produit est habituellement livr? avec le LaCie Setup Assistant. Une fois celui-ci ex?cut?, votre disque sera disponible sur votre ordinateur.
Le produit est aussi livr? avec le Genie/LaCie Backup Assistant. Une fois install? et ex?cut?, ce programme vous guidera afin que vous configuriez la sauvegarde de vos donn?es vers le disque LaCie.
Si vous croyez avoir effac? par accident le contenu du disque avant d'installer le logiciel, il peut ?tre t?l?charger ?: http://www.lacie.com/download/drivers/LaCie%20Genie%20Backup%20Assistant%208.0.364.534%20Win.zip pour le PC et http://www.lacie.com/download/drivers/LaCie%20Intego%20Backup%20Assistant%201.0.1%20Mac.zip pour le MAC.
Vous pouvez aussi faire une copie directe de vos fichiers vers le disque LaCie comme s'il s'agissait d'un disque local.
Faites moi savoir si vous avez besoin de plus de d?tails.
Mon PC portable ne connait pas digital camcorder VP D80
Avez-vous le pilote de votre caméscope numérique? Si vous installez le pilote. le pilote peut ne pas être compatibles avec Windows 7 et si tel est le problème que vous avez, faites un clic droit sur les propriétés du pilote et vérifiez. Changement dans les paramètres de compatibilité d'une ancienne version de Windows, puis accepter les paramètres. Avec cela, le pilote devrait fonctionner. Si vous n'avez pas le pilote, écrivez au fabricant pour le conducteur ou le télécharger sur leur site web
COMMENT CHARGER LE BATTERIE
Salut,
Vous pouvez recharger les piles si elles sont rechargeables.
Aller dans un magasin de vente au détail, ils vendent des piles rechargeables AA et ensuite obtenir le chargeur de batterie pour charger les batteries.
Cordialement
FixYa Team
1helpful
Bios damaged!
Le programme pour le BIOS est ici:
http://support.toshiba.ca/support/Download/ln_byModel.asp
Vous pouvez trouver votre ordinateur portable dans le menu et télécharger les utilités de BIOS de là.
Ceci a été traduit avec le bablefish et le Français est ma deuxième langue, ainsi je suis désolé au sujet de toutes les erreurs.
J'ai un appareil photo numerique canon powershot s300 digital elph et il ne s'allume pas il a ya un ecran noir ou il est ecrit " changer la batrie" dois-je acheter une autre baterie ?? de plus, je n'ai pas...
Pardonnez mon français, j'utilise Google. Oui, c'est mai-être temps d'acheter une nouvelle batterie. Batteries rechargeables ne sont pas faits pour durer éternellement. Ils devraient être remplacés tous les deux ans. Si votre batterie est plus vieux, alors il est temps. Heureusement, le NB-1LH batterie est disponible à partir de sources génériques de ces journées, et est relativement bon marché si vous recherchez.
Mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
INSTALLER LECTEUR CD-ROM
Lorsque j'ai un problème comme le vôtre, je trouve toujours plusieurs sites qui expliquent pas à pas comment installer des lecteurs cd et dvd dans un ordinateur de bureau.
J'ai fait une recherche rapide sur Google avec les mots clés 'comment réinstaller lecteur cd et dvd' et j'ai trouvé rapidement plusieurs sites tel celui-ci:
http://www.cnetfrance.fr/produits/installer-un-graveur-de-dvd-ou-de-cd-39157407.htm
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
