Question about Cyberhome CH-LDV7000 Portable DVD Player
Ac/Dc adapter Trying to find a replacement for the AC/DC adapter. Rating: DC IN 3.6v 3.5A
  • mspamb Jan 14, 2009
    I need an adapter for my Cyberhome CH-LDV7000 Portable DVD Player with screen ASAP.
Sorry, join the burned club. I have same problem. NO ONE has this power cord. 3.6v 3.5A is not even close to what anyone else has on the market. Radio shack, electronic warehouse's, Wall Mart, Best Buy, none of these guy's have it. The cord will have to be directly ordered from Cyberhome China. Good Luck!
My port. cyberhome dvd is in the trash dump, thats how I solved the problem. A good lesson learned.
randy
Posted on Feb 07, 2008
Replacing power supply in a Cuisinart CWC 1600 cooler
Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. his power supply replacement takes about 20 minutes. You need: Philips screw driver, wire cutter and stripper, two 16 gauge wire nuts. That's it.
Dec 01, 2017 | Furniture
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
Broke off my ac power supply nipple on the inside of my laptop where can I get a new one to solder on
Hi, if the Notebook is still under Warranty it is not recommended to remove and solder the Notebook with a Female DC Input socket of the Notebook. Although the DC input socket is available in any near by Electronic repair shop, please repair only if the Notebook Warranty is expired.
Mar 29, 2011 | Gateway MD7820u Laptop AC Power Adapter...
I have a Toshiba Satellite Laptop Model A15-S129 - The unit shut down and never would restart. I Checked the AC Adapter and it has no DC output voltage. I do have a 15VDC 2A Adapter connected to it now,...
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
May 17, 2009 | Toshiba Satellite A135-S4467 Notebook
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Dc power jack not charging
Even though the best thing you should have just done is to take along with you the AC Power Adapter that came with it, so as to get the exact replacement, but I will still tell you the best one for your PC.
Try and Make sure that the specifications for the one you will buy meets the this output power rating :
DC Voltage : 20V
The Current should be : 3.0A.
Product Number : 76-011651-5A
Hope this helps you out.
Mar 31, 2009 | Averatec 6100 Notebook
Ac/Dc adapter
you can find it any electronics shop...
Dec 06, 2008 | Durabrand PDV-709
Cyberhome CH-LDV7000 Portable DVD Player Logo
198 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
