Ipaq h1945 wont charge
I just got my h1945 from my dad, he didnt give me the manual, only the usb cord and the power cord, he got it to charge once for me before he gave it to me, now when I go an plug it in nothing appears to happen, the power button on top, which is saw turned white when charging, doesn't do anything, i would greatly appreciate your help so this isn't a lost gift
The power cord was tampered with by my siblings, I'm currnetly using my psp cord.
Posted on Nov 17, 2008
My iPaq h1945 won't connect to the Internet! Step-by-step needed!
best is you call your service provider for the internet settings ten once u get it save them and u are ready to go with the internet!!
reply and rate!!
Jul 15, 2010 | HP iPAQ H1945 Pocket PC
Hp ipaq wont charge from usb cable. turns on for a few seconds nd loads but then turns off. it wont fully charge.
On the the IPAQ 6515 and others, there is a USB Power option that you must enable to 'slow' or 'fast' charge from USB connection.
Jan 13, 2010 | HP iPAQ HX4700 Pocket PC
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Sep 23, 2009 | Compaq iPAQ H3630 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
No opperator instructions
all the documents for it are available at this hp site
I think you will find all you need there.
Let me know if you need anything else.
Feb 17, 2009 | HP iPAQ H1945 Pocket PC
Hp iPAQ h1945 won't start
Hello and sorry for the delay.
the h1945 series is a very intresting pda. I have seen all sorts of problems relating this one. There are some things you may want to try. Based on that knoledge I may be able to find what's rong with your unit.
First, check if the back cover fits tight on the back of the unit. It's important because on some ipaq models, there is a small micro-contact that doesn't allow the unit to power on if the back cover isn't attached. I'm not sure if the 1945 has one, it's been 2 years since i've last phisically repaired one of these, but you may look for one yourself. It's a small contact near one side of the back opening, check to see if it can be pressed. If you don't have anything like this just ignore this tip.
Second, leave the pda connected to the charger for about 6 hours. Even if it doesn't do anything. Then try to start the bootloader by pressing the 2 outer keys near the D pad (simillar to the hard reset procedure) then, while keeping those pressed, press the power button and in the same time press the soft reset button with your stylus. You must do this with your charger connected to the pda. It may be difficult to achieve in the first try. Just try to do this a few times and if the pda doesn't respond even now, please post back. Furthermore, if you need more info about these 2 tips please reply.
Mar 21, 2008 | HP iPAQ H1945 Pocket PC
Does not turn on
There are some known issues with the included charging equipment. Personally, I ordered a relatively inexpensive charger from that works wonderfully. All you really need is a device that turns a standard wall plug into a USB charger. You can then plug your base that the ipaq stands on into that and it should begin charging. The old battery is probably dead (mine was), but try to charge it anyway.
Note: The actual cord that came with my charger DID NOT WORK. It is sitting in a box somewhere, and if its the same thing I had (it probably is), then you just need the wall-to-USB converter.
This is what I bought:
It is only $10. Again, the cord didnt work for me. Maybe it will for you, but if you manage to find just that converter for less money, more power to you!
Feb 14, 2008 | HP iPAQ RX3715 Pocket PC
Are you displaying all categories. Does the second line of screen say 'All Contacts'?
Sep 11, 2005 | HP iPAQ H1945 Pocket PC
Replacing Nimh battery in iPaq h1945
check - they've got a pdf you can download and print. It shows 11 steps needed to replace the battery - comes with well written descriptions of each step and illustrative pictures - and its free
Sep 07, 2005 | HP iPAQ H1945 Pocket PC
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
