Question about Gb Electrical 1 30 Amp Ground Fault Circuit Breaker
Changing two light fittings
Changed light fittings switch on ok but when i switch them off they trip at fuse box
  • 359 Answers
Posted on Nov 23, 2008
A/C unit went down with no warning. Any clues???
Check power connection to the wall, check fuse box to make sure the fuse switch that handles th A/C unit hasn't been tripped, check all GFI outlets. If all else fails call your HVAC/Air conditioner repair company.
Sep 07, 2014 | Heating & Cooling
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
One light fitting not working when all others on same circuit OK.
I was facing the same problem with my truck and one of my friend suggest me to contact with good mechanic. There was some circuit problem..
Truck Service Repairs
May 16, 2017 | Cars & Trucks
Wall light fitting
you can check the switch .the fuse and fitting are ok .maybe there is something wrong with switch .
wall light
May 09, 2012 | Televison & Video
Brake light does not go on, fuse ok new bulbs stil no brake light when brakes are applied
check both fuse boxs if ok check the break light switch on stearing colum may be unpluged or bad
Jan 29, 2012 | 2000 GMC Sierra
How do you reset the oil change required light on a 2004 Ion
Press and release the trip/reset button until the oil life message is displayed.Then press and hold the trip/reset button until and chime is herd 5 times and reset is displayed in the message center.When the system is reset the odometer will be displayed in the message center.Turn the key to the off position.When you turn the key on if the change oil message is still there it did not reset.Retry again.Hope this helps.Good luck.
Feb 17, 2010 | 2004 Saturn ION
1997 gmc 3500 box truck. no brake lights. changed
check the fuse and maybe adjust the rod coming to the switch
Jul 25, 2009 | 2000 GMC Savana
My fuel pump is not getting power, I've changed the relay but still not getting power to the fuse or the pump
The fuel relay and inertia switch could be two different items. The inertia switch kills power to the pump. If there is a relay in between the inertia switch and the pump, then it would mean the inertia switch was tripped by slamming a door or an impact. Check your owners manual for the inertia switch. This website advertises online service manual reference.
Apr 26, 2009 | 1991 Volkswagen Golf
Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Apr 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Gb Electrical 1 30 Amp Ground Fault Circuit Breaker Logo
138 people viewed this question
Top Gb Electrical Electrical Supplies Experts
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
