The Product Key found by Magical Jelly Bean is not the correct Product Key for you to use when reinstalling Windows. It is the laptop mftr.'s volume license key. Since you have damaged the correct Product Key (on the COA sticker on the bottom of your laptop), contact the laptop mftr. for a recovery disk or further help.
SOURCE: windows activation error code 0xC004F058
Quick search got this answer:
Step set #1
1) Open Internet Explorer
2) A Browser will open, type: %windir%\system32 into the address field
3) Find the file cmd.exe
4) Right Click on the cmd.exe and select Run as Administrator
5) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
6) Hit the Enter key
7) Reboot 2 times
Step set #2
1) Open Internet Browser
2) Type %windir%\system32 into the browser address bar.
3) Find the file CMD.exe
4) Right-Click on CMD.exe and select Run as Administrator
5) Type: net stop slsvc (it may ask you if you are sure, select yes)
6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
7) Type: rename tokens.dat tokens.bar
8) Type: cd %windir%\system32
9) Type net start slsvc
10) Reboot Twice
11) Windows Vista may require you to enter a Product Key [use the Certificate of Authenticity (COA)] SLP Product Key found on the sticker on the side or bottom of your computer and activate. Use the Activate by Phone method outlined below.
From the Desktop:
a) If you have access to the Start button: Click the Start button, and type in "slui.exe 4" in the search field and then press the "Enter" key. This will bring up the Activate by Phone dialog window. Follow the steps provided by the window. The phone activation process should only take about 6 minutes.
b) If you do not have access to the Start button: Reboot and login to Vista, a dialog window will come up. In that window, click the option "Access computer with reduced functionality". Once you do that, Internet Explorer or Firefox browser will open. In the address bar type "c:\windows\system32\cmd.exe" press enter, a new window will come up, type: slui 4 and hit enter and follow steps to Activate over the Phone.
This all is if you have a true bought copy of Vista. If you have a pirated version, Im sorry to say I cant help.
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
