Question about Ducane 30400040 Stainless Steel Grill
Can't keep the Rotisserie to stay on
I have lit the rotisserie, and it stays on for about 5 minutes, and then it goes off. Not sure why? Could it be since its only 50 outside... it gets colder while its burning? Can't figure this one out. Dave
Called Ducane's customer service. Very helpful, they hooked me up.
1-800-382-2637 is their number.
Dave
Posted on Nov 18, 2008
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Rotisserie burner has to be lit with a match and will not stay on by itself. I have to push control knob in, even after it is hot. Also looking to replace igniter for left burner. Thanks.
From what you are describing, it sounds like your rotisserie burner may have a bad thermocouple. You can order the parts from Viking, the igniter for the left main burner will require you to remove the front panel to replace, but is fairly straight forward after that. To replace the thermocouple, you will have to fish it down from the burner and under the grill to behind the front panel, not hard, just time consuming.
Jun 19, 2011 | Viking VGBQ410-3RT Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
My rotisserie burner keeps shuting off
If yours is an infrared rotisserie burner, it's equipped with a thermocouple. Since infrared burners are hard to see if they are lit or not (depending how the sun shines on it), the thermocouple provides a safety net, in case the burner goes out (blown out by the wind) for whatever reason. I assume, yours is going out without the wind blowing it out ... the thermocouple may need cleaning due to a grease splatter build up. A cotton ball dipped in alcohol works well for this. In addition, check all the connections for the thermocouple (from the gas valve to the thermocouple) to make sure they are secure. If they are loose, tighten them with the appropriately sized open end wrench. But, do not over tighten them.
Troubleshooting what I listed above should solve the problem.
Apr 12, 2011 | Grilling
Flame does not stay on Rotisserie Burner grill but jumps back into the throat where the air mixes with the propane gas. What's wrong and how do I fix it?
If it's windy outside when this happens, the wind is blowing the infrared burner out. Especially if the hood of the grill is open. The Rotisserie should only be used with the hood closed.
Feb 09, 2011 | Grilling
Infrared rotisserie burner mounted on back will not stay lit.
I have the same problem - What I determined is first the gas safety valve button would not push in. I researched the problem and found that if you ever overheat your grill by "cleaning it" by placing foil over the grill, then the intense heat likely overheated the valve. ( in my case) which I replaced. After replacing the valve, my rotisserie would not stay on. I found that the thermocouple was defective. the TC is a piece of copper that attaches to the back of the safety valve and the other end has a probe that is up at the rotisserie burner. When you light the rotisserie, and press in the valve button, it should stay lite after about 10 seconds.
When the probe heats up, it sends and electrical signal to the electro magnet which operates and keeps the valve open. I bought my thermocouple from PEX supply for $9.50. DCS wants $56.00 for the same part which is manufactured by Robertshaw. Part number you want is 1980-072 thermocouple .
Dec 07, 2010 | DCS BGA48-BQAR (NG) All-in-One Grill /...
I have Jenn-air gas grill, model no. 720-0336, the back burner that we use for the Rotisserie does not stay lit. Once started it will run for three minutes or so the you'll hear a pop...flame goes...
The tube to the third burner or the burner itself is clogged. Spiders are the usual suspects. Unhook them and clean out with circular brush or compressed air.
Please rate my answer 4 stars if it helps.
Good luck,
Oct 24, 2017 | Garden
Using rotisserie in Bravetti Platinum Pro Toaster Oven Broiler
no the bottom element stays off when rotissereie is used . if it was on the liquid that drips from the cooking meat would smoke or might even start a flash fire ....... if this answer helped please rate a3 or 4 stars this high rateing will help keep me in the paid answer department thank you
Apr 01, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Rotisserie won't stay lit
With our Kenmore, you need to increase the gas flow another 1/4 turn once it's lit.
May 25, 2008 | Grilling
Ducane 30400040 Stainless Steel Grill Logo
212 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
