Question about Gateway 7330GZ Notebook
Notebook Gateway 7330GZ won't boot
I turned on my notebook and it is stuck on the Gateway screen that says BOOT Menu F10 and BIOS Settings F2.
It will not go any further and it will not respond to any keys.
  • floramarche Dec 22, 2008
    My 3-month-old notebook has the same issue. It started after the last round of Microsoft updates but I don't think that's the problem. A USB keyboard allows me to use the computer but I have to press either F10 or Esc and boot the computer up.
  • ryanjasa2004 Dec 23, 2008
    I have this same problem currently, with the same model, what ended up working for you?
Hold f8 (or  f10) on boot up...  select menu item: boot from last good configuration
Posted on Mar 10, 2009
    Scholar:
  • 44 Answers
Hm...That sounds like either the motherboard is dying/dead or a device is (such as the hard drive). I would suggest removing one piece at a time and see if you can get past that screen. The most annoying would be if it is the DVD drive since it's probably the most difficult device to remove from the laptop. (If memory serves it involves removing a certain screw from the bottom and then getting under the keyboard so you can push it out).
Do you have a second stick of RAM installed? Mine died a while ago and caused real heck with my 7330GZ.
Posted on Dec 12, 2008
How to enter bios on gateway LT2802u?
i can tell you what to try... its going to be the delete key, f2, f10, or f12... when the machine is first starting to turn on (boot) steadily tap one of those keys and it will get you into the bios. try del first, if that doesn't work, then try f2... go down the line, one of them should work for you.
May 08, 2014 | Gateway M305CRV Notebook
Cd rom boot
Follow the steps below to configure the boot order on most computers.
  1. Turn on or restart the computer.
  2. While the display is blank, press the f10 key to enter the BIOS settings menu.
    NOTE: The BIOS settings menu is accessible by pressing the f2 or the f6 key on some computers.
  3. Select the Advanced tab using the right and left arrow keys.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Nov 06, 2013 | HP EliteBook 6930p Notebook PC
What bios settings work best with mt6705/windows 7
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Nov 05, 2012 | Gateway MT6705 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
Computer freezes during recovery
Type F2 at boot and go into bios. On the Advanced menu -> disable speed step. Type F10 to save settings. Retry the recovery, it should complete this time. Once the install has completed, update from the microsoft web site. Make sure update kb885626 is installed before you enable speed step.
Sep 27, 2009 | Gateway 7330GZ Notebook
Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Jun 17, 2009 | Acer Aspire 3680 Laptop
Gateway laptop m675
Seem to be an inverter problem.
Sep 24, 2008 | Computers & Internet
Gateway notebook
such problems normally i associate it with ram(memory) and or hard drive. so what i suggest yu do is first lose the area where the ram is, bring it out then put it back in place. then restart yr system n see if it hangs. if u have more than one ram in yr system then try testing then one after the other not just putting the 2 at ones..next try removing the hard drive then power it on n see what happens.next if u can enter into the bios setting good there yu can restore default settings fto manufacturers design.
b4 bringing out any hard ware from yr system try removing batteries first then from power as well.
good luck as u do this
n do come back to tell me the extend yuv gone
May 29, 2008 | Gateway 7330GZ Notebook
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Gateway 7330GZ Notebook Logo
432 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
