Question about HP Office Equipment & Supplies
No power to printer. was working when i first bought it but not working now, only had it just over a week
  • 33 Answers
If you just bought the printer new and only had a week i would retrurn and get a new oen
Posted on Nov 16, 2008
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
When you plug it in, (lexmark pro 205), there is a white light in the display box but no words or pictures and the on button does not light up. the only way to shut it off is by unpluging. It does...
Try to rebrick your printer. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will give enough time for the printer to reset itself.
You may also try to plug the printer to a different known working power outlet in the wall to identify if it's a faulty power outlet issue.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark Prospect Pro205 Wireless...
Bought a lexmark x4650 on July 31, 2010. Three weeks ago it failed to power up, however I can see the red light is on inside the printer for the wireless to work. This light goes off when it is...
Try to remove the power adapter from the printer. The power adapter is the rectangular black box behind the printer where power cord is attached. Replug after 15 seconds. That should give the printer enough time to reset itself. If printer won't automatically power on, press the power button. If that doesn't help, try to plug the printer to a different known working power outlet in the wall. Bypass any surge devices or power strips. If problem continues, it could be defective power adapter issue or worse. If this is the case, please contact Lexmark technical support for additional assistance. Thanks.
Dec 27, 2010 | Lexmark X4650 InkJet Printer
Bought in Nov 2007 online from circuit City. Has
Change printheads,Issue will not get fixed then its a hardware failure.
Jul 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
I just bought a new canon pixma mx 328, and to save money i bought a refill ink. I forget to refill the ink for two week until it dry out. when i try to print the error uo51 is on the printer screen. i...
Try to reset the printer using this procedure.. might help. turn off the printer..press/hold the stop/reset button..press/hold power button..while holding power button, release the stop/reset button.. then press the stop/reset button twice..release power button..wait until the power button lights a steady/still green and says "idle"... open the cover...take out both catridges.. then turn off the printer. put back the cover then turn on...now put the catridges back.. and wait for 10 seconds then try to print... try this one.
Feb 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Will not power up
Sounds like the X125 is shot.  Cheaper to replace it than to fix it.
Jan 08, 2009 | Lexmark X125 All-In-One InkJet Printer
I have bought a lexmark fax,printer,copier X4270 two months ago and it is not working.I do not want you to call or offer me a dicount on it being repaired this is the second lexmark one that I have bought...
IF your printer is 2 months old then if not working you can contact Lexmark and get your printer replaced as its under warranty for free by the company ...
Good luck..
Aug 18, 2008 | Lexmark Office Equipment & Supplies
No power.
Hi there try a different power socket in either your surge protector or on the wall. If this doesn't work I think something is blowing the power board of the printer check your electrics.
Thanks J
Feb 04, 2008 | Lexmark P315 InkJet Photo Printer
Printer doesn't work
The answer is probably down to the usb port, they don't always like change, because you are trying to swap hardware in same port, they tend to want to stay with one or the other peice of hardware. If you have'nt got another spare USB port, which i assume you have'nt, invest in a 2 or 4 port USB hub(But make sure it's powered by a AC power lead and not just a usb powered hub, because some hardware will not be recognised e.g I Pods), this connects into your usb port and gives you 2 or 4 port more to use, and you won't need drivers for it. They are inexpensive and you simply plug it in. I think this will solve it for you
Oct 23, 2006 | Samsung ML 2010 Laser Printer
Ben Johnson
