Question about Toshiba 40H80 40" Rear Projection Television
Green Picture with 40H80?
My picture is green almost all the time? Start off back in Aug 06, it was seconds at a time, then mins, then hours? Any idea what part(s) could need replacement-- is it easy to myself or should I call a repair man? Tx
    President:
  • 3,130 Answers
This is a CRT type projection TV set. You could have a bad green picture tube, a bad connection on one or more of the picture tube sockets and or driver boards, or there is a RGB driver problem in the video jungle IC or the output driver transistors. If you have had any experience with solid state TV repair, there should be no problem figuring out whats not or is working in this set. If you have not had any experience, there is alot of high voltage on these picture tube sockets, and one wrong move and you will get a perm of a lifetime. That voltage hits you so hard, I have seen it make a grown man cry. Play it safe and call in a pro to assist you in this repair. Good Luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Problem with rca hd52w58 52" tv
This can be a green crt or green driver pcb problem. You can try and unplug the tv for 30 min. and plug it back in and turn it on, but the problem will most likly still be there. A repair shop will need to fix it from there.
Oct 22, 2008 | RCA HD52W58 52" TV
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound, No Picture
The only thing you can do is to unplug the tv for 30 min. Then turn it back on and see if that fixed it. If not call a repair man, you are most likely missing a power supply voltage or deflection voltage.
May 26, 2008 | Toshiba 40H80 40" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Toshiba Rearprojector TV
you didnt say if the set was working?? if its not I would first try the power regulator IC in the power supply It will start with an STR#####.. This goes bad alot in these sets. Good luck
Apr 17, 2006 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
