Question about IBM ThinkPad T20 2647 Notebook
Thinkpad T20 won't recognize usb port
My thinkpad T20 will not recognize the usb port. I need it for my pc internet. I know the port is getting power, it just win't recognize anything I plug into it.
  • 1 more comment
  • Anonymous Dec 10, 2008
    pls drivers download
  • Mark Robinson May 11, 2010
    T20 has usb 1 so very little power goes through it....are you plugging in a usb 2 device ?
  • comment
    comment May 11, 2010
    Have you tried both ports?
    If you check My Computer> Manage> Device Manager, do the USB ports show up? Any RED X's in the Device Mamager, anywhere?
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Posted on Jan 27, 2009
    Scholar:
    New Friend:
  • 98 Answers
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Posted on Jan 05, 2015
Get usb ports to work
Usually you don't need to do anything for any Windows to recognized the USB Ports. I will say that if the for instance a flash drives is not seen that you make sure that works in another PC.
Sometimes Windows gets confused if many USB devices were used and then removed. Eventually it will stop recognizing anything that is inserted. If you know how to use the registry you can fix it but if you don't better not try it. Your other option is to re-install Windows.
As a technician I could some other things before re-installing so I will leave like that for now.
Nov 28, 2014 | IBM Lenovo ThinkPad T400 7417 Notebook
Does not recognize hard drive
1. try reseating it if that doesn't help you might have a hard-drive failure. the only way to be sure is trying a replacement drive (maybe you can borrow from someone or from another laptop - currently on laptops there are 2 types of hard drives IDE and SATA don't mix them up, they are not interchangable)
May 25, 2010 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T41 won't recognize USB 2.0 Ports (sees them as USB 1.1)
all available ports are not recognized? have you tried other known good usb devices on those ports?if other devices are recognized then it is an issue with the usb device you were first trying to hook. if not, then it may be the port issue or driver. so update chipset driver for your pc. use ibm's website to check for drivers of your pc.
Mar 31, 2010 | IBM ThinkPad T41 Notebook
I have a 4 yrs old IBM Thinkpad (Model R51) and its USB port is not working. There are some lines on the screen as well. What is the cheaper way to get it sorted out. Somebody told me motherboard has to be...
There are several PCMCIA USB ports available, I have an IBM T20 and I bought a Belkin USB 2.0 card from ebay for under $20, it has 2 USB ports, (and I've seen them with up to 4) and most electronics store should have them. They also come with Firewire ports if you choose to go that route
Sep 24, 2009 | IBM ThinkPad R51 Notebook
T20 usb ports. can't find the second one.
Hey,
the other usb port is most likely used inside the computer possibly a memory card reader or other integrated device is using it.
if you can't find it on the laptop, then its internal.
Let me know if you need anything else.
Thanks,
Ekse
all information you can provide will make it easyer for me to help you to solve your problem.
Feb 09, 2009 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20
Wow, a lot of information but I'm unclear as to what you are trying to do.
Are you connecting the T20 directly to the T40 using a cat5 cable and then trying to access the internet on the T20 via the modem?
Connecting the two computer together using a normal cat5 will not work, you need to use a crossover cable otherwise you are connecting the send to the send and the receive to the receive.
You can also use a hub, a switch or a router if you have any of those on hand.
As for the modem, I suggest you unplug the telephone line from the modem and plug it into a phone and see if you can hear a dial tone. If you cannot hear a tone either the extension is bad (replace) or you outlet is defective. If you can hear a tone, the modem card may be defective.
Oct 08, 2008 | IBM Thinkpad T20 Notebook
Windows doesn't see T20 on any USB port
It sounds like the USB plug-in on the player itself could be damaged. I would call the manufacturer to see if you are in warranty - if the volume+/force recognition method does not work, then we are in a bind. You could try uninstalling/reinstalling the software, but I doubt that it will work, because none of the other pc's recognized it - double check the manual to see if there is a hold/lock switch - if it is pressed, then no pc will recognize it.
Jul 04, 2008 | iRiver T20 MP3 Player
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
Internet Connection
hi, in :My network places" u can see this wireless local area connection, on the right hand side menu, there is an option to creat a new connection, clickon it and go step by step, u will figure it out.. keep handy ur ISP network details.. let me know
Jan 13, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
541 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
