Question about Onkyo TX-SR606 Receiver
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
The output are listed right this is a brand new reciever
Try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Posted on Dec 07, 2008
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
I am having HDMI output issues to my HD TV. The issues are intermmitent. I have my HD cable box, BluRay Player both hooked into the reciever via HDMI. The Hdmi output of the reciever feeds my TV. I have...
Have you proven that a straight shot HDMI to the TV from either source solves the problem?
For all we know the TV or it's HDMI cable could be faulty.
Apr 09, 2010 | Onkyo TX-SR606 Receiver
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Oct 19, 2009 | Onkyo TX-SR606 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
No sound after plugging in HDMI cable to computer.
I think this is dependant on your graphics card in your PC. Most PC's with HDMI ports are purely for video not audio, check with your PC manufacturer/graphics card manufacturer to see if it supports audio from the HDMI port.
You may just have to link the audio from the audio output port on the PC to the reciever for audio and HDMI for video.
Jul 07, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
246 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
