Question about Sony KP-53V85 53" Rear Projection Television
Getting my tv crisp and fixing hdtv
My tv has little black lines that run through it i am a quality freak and i can't stand it is there any way i can adjust something to make it more crisp of a picture, it's also blured on the right side and the bottom of the screen. Also when i plug my hdtv in i get a slpit screen with the same image on both sides any way i can fix this or where do you think the problem is?
    President:
  • 4,402 Answers
Check to see if set appears to have a slight high voltage arc or corona discharge that is causing interference to other televisions. This arc is also causing problems in the video circuit which is why the tech and the customer are seeing it on the screen of this television. Tech needs to isolate the High voltage block, and CRT from possible suspect by one by one disconnecting them from the high voltage source. The only indicator the tech can use is another television and look for the interference to disappear, since the Sony will not allow the raster to appear if any one of the tubes is disconnected. After the test the it was determined the flyback was causing the problem. The radiated noise reduced but was did not disappear. It was recommended to replace the "G" board since the unit was covered under the SAYS program.. The G board corrected the symptom.
Posted on Jan 15, 2008
SOURCE:
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Es de 1080p o de cuanto
Product Description 37" HDTV, LCD Widesreen, 1366 x 768 resolution, 720P, Integreated ATSC tuner, HDMI, 2 HD component and 2 S-VHS inputs, 3D combi filter, Delivers Crisp Sharp High Definition picture quality, built in speakers for high quality audio sound. ES DE 720P
Dec 14, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Jan 22, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Sanyo 27" Problem: Fuzzy Screen
sanyo does this alot it is either you need to replace your tuner or you have two resistors 220k ohm s that need to be replaced.this will fix your problem.if repair cost is cheaper to fix then buy a new one its up to on that one!
Dec 01, 2007 | Sanyo DS27910 27" TV
Fuji FinePix S602 Zoom - Black strip down picture
If you see the black line on your images and it is a very crisp clear line then it is an issue with the cameras image sensor. If the line is less crisp and clear then it may be a more simple of contamination in/on the lens. If the line is crisp and clear and the camera is under warranty get it fixed or replaced. If it is out of warranty look into getting the CCD component replaced at a repair facility. There is an outside chance that it is just the connector which bridges the sensor to the processing board - but that usually manifests all over the image, not just in 1 strip. David Millier Advance Camera Repair
Feb 11, 2007 | Fuji FinePix S602 Zoom Digital Camera
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Vertical lines
The red line in the crt is the sreen voltage is to high or bad tube.
A simple fix is if you take off the front panel there will be a black box be careful it is high voltage make sure you are a pro.
there will be six controls look for the one marked screen and is for red tube adjust very slightly counter clockwise.until red
line gos away. If that does not fix it its the red tube.
I hope this helps doctor video
Sep 21, 2006 | Akai PT5598HD 55" Rear Projection...
Sony KP-53V85 53" Rear Projection Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
