Question about Panasonic KX-T7730 Corded Phone
Kx-tga270s phone system and i wanted to add another handset
You provided a solution for this below. However, I don't know what you mean by "menu". I don't see that key/button. Can you help me alittle bit further? ********************************************************** I have the kx-tga270s phone system and i wanted to add another handset. I fully charged the battery but get "no link to base...." message. what do I do next?
Thanks,
Liz Solution #1 posted on Jan 28, 2008
maxww
Rank: Apprentice
Rating: 100%, 1 votes
PUT NEW PHONE ON BASE; PRESS MENU; PRESS ZERO (0) TWO TIMES; # # # ENTER A NUMBER YOU WANT ASSIGNED TO THAT NUMBER; CHARGING LIGHT SHOULD COME ON; ON YOUR EXTENSION PHONE SITTING ON THE BASE WILL HAVE AN OK COME UP IN THE BOTTOM RIGHT HAND CORNER OF THE DISPLAY. PRESS OK. HOPEFULLY YOU WILL GET ON LINE. PAGE 46 OF MY HANDBOOK FOR REGISTERING A PHONE. . TO REGISTER YOUR FIRST EXTENSION HIT 0-0 ; PRESS AND HOLD "INTERCOM" UNTIL THE CHARGE LIGHT STARTS FLASHING; THE PRESS THE OK BUTTON THAT SHOULD COME ON YOUR DISPLAY.
  • 173 Answers
SOURCE: Network woes with MA101
Question
What is a "code 2" error
Question
What is a "code 2"
This error occurs when the BIOS did not assign an IRQ to the device. This is most likely to happen on a system that is not PCI compliantand/or is not capable of Bus Mastering. In such a situation a suggested ISA Ethernet Card would be the best sol
Error message "No domain server is available to authenticate user password"
There are any number of reasons this can happen. Please check for the following:
Verify ALL connections to the network are valid (cables, connectors, ports, etc.)
If there is no NT Domain server on the network:
1. Right-click Network Neighborhood, then select Properties from the list.
2. Double click Client for Microsoft Networks.
3. In the new window that appears, uncheck Logon to NT Domain. Click OK on all open windows, and restart the computer when prompted.
If there is an NT Domain server on the network check to make sure that:
1. An IP address has been specified.
2. The computer has been configured for DHCP.
If DHCP is configured and the error message continues to come up, ensure that the DHCP service is running correctly. Contact Microsoft, or your network administrator for assistance with this.
for more clarification log in to http://kbserver.netgear.com/
Posted on Dec 09, 2007
  • 14 Answers
SOURCE: tv works when it wants to
Make sure you have plenty of air circulating around the tv. If the tv is cool and you turn it on no problem, but if you watch the tv and turn it off, then watch it again it might not have enough air to cool down enough to temperature where it can operate properly.
Posted on May 16, 2008
  • 3 Answers
SOURCE: soldering
HI: UNLESS YOU HAVE SOLDERED AROUND SEMI CONDUTORS BEFORE STAY CLEAR. HEAT SINKS ARE REQUIED AND CORRECT HEAT IS THE KEY, LEADS MAY BE OF NON COPPER AND THI WOULD REQUIRE HIGHER TEMP IRON. IF IT TINS EASLY THEN GIVE IT A SHOT. BEND LEADS HELPS
Posted on Jun 21, 2008
SOURCE: ASPIRE 5720Z ACER WEBCAM
in site official of accer driver webcam ASPIRE 5720Z for vista have 3 option driver. u can try it.
1. logitech (download)
2. Suyin (download)
3. Bison (download)
good luck.
best regard by yunus
Posted on Aug 19, 2008
  • 1861 Answers
SOURCE: TRAC LIGHT ISSUE
The trac light does NOT come on for the smog test. It has noting to do with the smog test. The trac light DOES come on when the Check Engine light comes on, when a failure is detected. From what I remember, the trac light WILL come on if the smog is a "dyno-driven" smog test, but it has nothing to do with the test, the trac simply comes on because only one wheel is spinning, just like it will when you are spinning on ice.. Hope this helps.
Posted on Nov 06, 2008
Ringer
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG2740S
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Apr 21, 2010 | Panasonic KX TGA270S Cordless Expansion...
I have a Panasonic multi talk phone 2 line phone, model KX-TGA270S. Somehow , it shows "ringer off line2" I can't find a way to remove this. What does it mean? Line 2 still rings
I have a Panasonic Multi-talk KX-TG2740 and I need to change the outgoing message. Anyone know how to do this? (There is no "greeting" button as mentioned below).
Thanks!
Sep 07, 2009 | Panasonic Lands Phones
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
Hanset ringer off line
Hi - You can download the manual from the link below:
kx-tga270s
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 05, 2008 | Panasonic KX TGA270S Cordless Expansion...
Carnt change the time on my phone
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
Nov 13, 2007 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
