Question about ViewSonic VX910 19" LCD Monitor
Blinking Light on my vx190 the power light flashes green and nothing on the display its completely blank
  • 7 more comments
  • bamamcse Nov 03, 2007
    I have the same problem. I have a VX910 LCD that when you plug it in, the power light just blinks..no display at all.any suggestions?
  • Kevin Capatch Nov 10, 2007
    Have the same problem - cah you suggest a site to buy parts the viewsonic store does not carry any parts
  • Anonymous Nov 15, 2007
    Yep me too
  • Dazd Nov 25, 2007
    Same here...took it apart to see what might be amiss and could not diagnose, it makes a buzzing sound as it cycles on and off. ANY help is appreciated.
  • Converse2 Nov 26, 2007
    One day the screen went black and the little green led on the power switch started to blink at the rate of about one second off and one fourth second on. I don't know how to make it go away. At first the problem was intermittent, or anomylous but now it seems more persistent, like a systematic or engineering design or parts problem. ViewSonic denies the problem even exists. Mine is a VX924. It sounds like the same problem. It is a bad problem since it turns the unit into very expensive garbage.
  • emmaco Jan 11, 2008
    Green light powers on and beeps, no display on screen, no response from Viewsonic on troubleshoot. Had to buy a new monitor as our business is dependent on our computers working.
    Is this thing repairable, and is Viewsonic still in business? I waited on the phone for 45 minutes today without anyone picking up. They advertised 24/7 lifetime support when I bought it.
    Not impressed with Viewsonic. Seems like a common problem on the internet and is not addressed on their useless troubleshooting menu.
    They have an online system that pretends to have live support behind it.
    A fraud.
  • Anonymous Apr 25, 2008
    PLUGGED AND SOMETIMES IT COMES ON
  • Neubian Sep 09, 2008
    Was working on it an it just went black. Now the power light blinks when you turn it on, though it's a long, slow blink.
    I looked inside for broken capacitors. I found some that were bulging quite a bit on the power transformer board. Everything on the LV side seemed fine.
    Any advice?
  • KLear May 11, 2010
    I am having this problem too with my VX924. Flickers on and off for like 30 minutes until it settles to on. Now is actually even longer. Now trying to test the components, BUT... I am stuck to opening it. Could anyone please either reply here or post a link to a bit of info on how to physically open this LCD display. Many Thanks
    Scholar:
  • 42 Answers
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Posted on Mar 18, 2008
Bought a new power supply as well. Didn't change a thing, still dead.
Posted on Feb 21, 2008
Don't know if I'm allowed to advertise here but I ended up sending mine to Monitor Depot in Houston Texas, $110 including shipping and its back working...Wish I could have fixed it myself but there is nothing out there to help...Still a good monitor so I decided it was worth it.
Posted on Jan 04, 2008
  • 3 Answers
Having the same exact problem...it started with the green led power light flickering and it would take a long time to come up and then it got progressively worse...now the led light flickers red, yellow, green and the screen displays white lines randomly as the led light flickers...seriously doubt that the monitor is repairable....paid $500+ bucks for this sucker and have only had it for 1.5 years...have 3 CRT monitors that only cost $100 bucks from the mid 90's that are all still running strong (none are ViewSonic monitors), so needless to say we are very very disappointed in the QUALITY of ViewSonic Products. Our Company Will Avoid ViewSonic Porducts at all Costs in the Future!
Posted on Jan 03, 2008
    Scholar:
  • 116 Answers
Viewsonic/Proview monitors are all notorious for this! I have to go into various sites to troubleshoot these monitors. These monitors have two major components that allow you to visibly see what is being display! These two parts are critical the Inverter & Backlight. I have found that whe the flickering begins, distorted lines, grey screen, multi-colors, lines in meshed in the LCD, blinking power light, solid blue screen, solid green screen. These are all major causes of bad inverter, or blown backlight! Now if this monitor has a power supply that connects directly into the serial connector that connects to the PC, then it could definetly be the power supply. Power supply is important as well because sometimes they do not put out enough power to display the image so if these monitors all have a power brick connected to a power cord. Then the power brick is the problem! I see this all of the time with these monitors! Let me know!
Posted on Nov 26, 2007
Hi had the same problem blinking power led called viewsonic the power supply was faulty bought a new one for 38.00 work like a charm easy to install :-)
Sanyo dp42849 completely black screen, green light blinks every minute.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 26, 2014 | Sanyo DP42849 42 in. HDTV
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
No picture and blinking red light on Panasonic Viera Plasma TV model P50XT70A
Your Viera is showing symptoms of internal power supply failure
Mar 19, 2013 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My monitor is blank. The power light is blinking ...
Throw it Away and buy a new one (its cheaper)....
May 14, 2010 | Computers & Internet
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
ViewSonic VX910 19" LCD Monitor Logo
1,295 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
