Question about LG WM-2077C Front Load Washer
Should I use powdered or liquid detergent in my front load washer
  • 903 Answers
It depends, I use liquid so the dispenser drawer does not get a build of of soap and cause blockage problems. But if you decide to use power that is fine too, but I recommend that you take the drawer out at least once every fortnight to give it a clean.
Posted on Nov 16, 2008
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
Where to put the powder detergent in the washer? how come did not dissolved?
Chances are that the washer is a front load. If it is it requires liquid detergent. If you want to use powder put it in with the clothes and not in the top detergent well.
Hope that clears things up.
ash
Vote please.
Sep 22, 2010 | GE WSXH208A Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent will not dispense
generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Mar 07, 2009 | GE WSXH208A Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
How to add liquid detergent and powder booster at the same time?
any booster would go in the detergent dispenser,should not be a problem if you are doing warm washes.if you do alot of cold washes,check for build up and clean from time to time.
Sep 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
LG WM-2077C Front Load Washer Logo
234 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
