Question about Dell E173FP (Black) (Dark Gray) 17" LCD Monitor
Dell E193Fp Blue Screen
Our Dell flatpanel display has a blueish tint to it that I can not remove with control settings or color adjusts.
  • 4,889 Answers
It can be due to the effect of some kind of magnetic effect.. If your monitor has the degauss feature then degauss it ONCE and see if returns to normal. Do not use degauss feature more than once in less than half an hour. It can damage your monitor.
Posted on Nov 16, 2008
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Monitor colorization problems
1.) Check to see if the screen has a peel-away, cellophane type shipping protector on it ( transparent with a rose color tint ? ). 2.) Click Start >> Control Panel >> Display >> Settings >> Advanced. If this section has a tab labelled "GAMMA", you can manually adjust all display settings. 3.) If no gamma control is available - download one FREE ( Dark Adapted ) here >>
Dec 25, 2008 | Computers & Internet
Pink tint on Dell 1704FPT Flatpanel LCD
Unfortunately if you have tried a different machine (it could be a bad video card) and tried the cables most likely it is the screen itself. Typically when one of these lcd's begin to fail the pixles no longer access the blue field and you see mostly red instead of the other two colors. In short pink screen is terminal, it will last for a while longer.
Oct 01, 2008 | Computers & Internet
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out.. has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
The color of the screen is not correctly appearing.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
Dec 26, 2007 | Chi Mei Corporation 221D-NBC Monitor
Dell E173FP (Black) (Dark Gray) 17" LCD Monitor Logo
213 people viewed this question
Alun Cox
