Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Tv turns off then on
After the tv is warmed up it will turn off every 10 min and then turn back on around 30 sec later. when the tv is off the green power light blinks around twenty times. the lamp was replaced 2 years ago
    Problem Solver:
  • 19 Answers
Yup, it seem a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breat because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Posted on Jan 14, 2012
  • 320 Answers
It's time for a new lamp. What you are seeing is the result of a weak or old lamp and the TV sensing that it is drawing too much power and turning it off. I've seen this many times; a new lamp will cure. Be sure to buy an original Sony lamp as the aftermarket replacements are known to have problems. Please be sure to rate this solution. Thanks!
Posted on Nov 16, 2008
How do i fix my tv
I had the exact same problem. Thought I could fix it by replacing the thermal fuse . . . no luck there. Problem continued. After tons ( I do mean tons) of research, I found the problem to be a temperature sensor. Makes total sense ! ! ! The tv is trying to come on, but the temperature sensor is bad, telling the tv that it is too hot to operate, so it turns itself off - only to try & come back on 30 secs or so later. Hard to fix unless you know your way around tv circuits. Took me bout 3 hrs total.
Nov 08, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Magnavox tv
the automatic code is actived.
Nov 09, 2008 | Philips Magnavox 42MF521D/37 Television
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
