Question about Amana AGDS902 Gas Kitchen Range
Amana gas range will not heat up in bake mode
Used self clean cycle two days ago and canceled clean cycle before it was completed. now when we turn power on, after tripping circuit breaker hoping that would reset oven , the # 40 shows on the readout for a second and then clock shows.
It turned out to be the igniter...a friend tested it and found it to be bad.....
Posted on Nov 17, 2008
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana AGR5735QDS. Bake/Broil don't work, Clean/burners do work
Hello- Most problems with todays ranges start after 'self clean', or as most techs call it- 'self destruct'. If control functions normally, the temp can be run up manually by holding button down until it reaches 500deg., then holding it down until it stops and reads 0 or +/- 5,10, etc. This is a temp adj. mode. If it won't adj. or work at all, control is bad. If it works, then twin ignitor failures are not unheard of. Resistance across either ignitor should be above 4 ohms., if not, they have failed. Avoid 'self clean'. Tears electronics up and wastes energy. Use drip pans and try to forsee boil overs. Grandma figured it out a long time ago. Hope this helps. Thanks- ED
Mar 01, 2010 | Amana AGR5735QDS Gas Kitchen Range
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Apr 17, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana range ARG7800E Oven, Broiler and Self Clean will not ignite
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
tti
Apr 07, 2009 | Amana ARGS7650SS Gas Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Amana AGDS902 Gas Kitchen Range Logo
691 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
