Question about Palm TX Handheld
Cannot print images from Palm TX--Notebook section
Images download to Palm page on the computer, but "print" function seems to be non-existent. Any ideas? I need some of the drawings that are in there. Thanks,, NEF1
  • 7 Answers
Not sure what you mean by "Notebook section", but you need to have a print software installed on the TX to print directly to a printer (without a computer). You can use PrintBoy: http://www.palminfocenter.com/view_story.asp?ID=1651 It will enable you to print wirelessly from your TX. Otherwise, try using CardReader http://software.palminfocenter.com/product.asp?id=2062 and your USB cable to connect your palm as a usb card reader, to your computer. Then you can transfer the images or any needed files to your PC.
Posted on Feb 09, 2007
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
I have all the softwares installed in my computer. I have downloaded images no of times. But its not happening now 1) Camera gets connected to computer 2) The window appear on the computer Where i click on...
Find out where "Canon Camera Window" points to for its default pictures Folder and change that path or create a Folder in the location where it is pointing to ...
It seems to be directing the pictures to a non-existing Folder !
Sep 27, 2009 | Canon Digital IXUS 860 IS - Digital camera...
Cant get online images with my palm tx, is it a java update
Most of the time it is a software update that is needed. Download the software from your installation CD or you can go to www.palm.com and click on support to get the newest version of the software. After that just hotsync it and it should work the way it was designed. If that doesn't work palm has a chat feature on their website to tey out where you can chat directly to a palm rep. Best wishes.
Aug 17, 2009 | Palm TX Handheld
Bought TX but have no desktop software cd
HI,
Yes if you go to palm.com you will find a section for support. You can download everything you need there to get your PDA up and running. Once you have the software installed on your computer you will want to go in and enter all your information like names and addresses in your contact section. Once you have that all done you connect the PDA to the computer by using the usb cord and then hit HotSync. You can go back later and update any of your infomation right in the PDA itself. Best wishes. Let me know if you need any other help with this.
Aug 11, 2009 | Palm TX Handheld
How to find the program for taking pictures from my pc in acer aspire 7720-6182???
Go to www.filehippo.com
Look at the the Imaging section and find Picassa click on it and it will open a download page
This program allows you to modify your images , print and store them
Jun 05, 2009 | Acer Aspire 7720-6155 Notebook
Dropped my Palm TX, IR no longer works
I went to the Palm support website. It seems that after any reset, including a soft reset, the Beam Receive function has to be re-enabled. Follow this path:
  • Applications==>Prefs==>Power
  • Beam Receive==>Off==>On==>Done
For more information: http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,CASE=obj(14838),ts=Palm_External2001
I also updated the driver for my Palm wireless keyboard.
http://www.palm.com/us/support/downloads/universal_wireless_keyboard.html
Cheers!
Nov 25, 2008 | Palm TX Handheld
JPG files
The picture program that comes with the Palm software should be loaded into your Palm.
Do you see an icon on your desktop for it?
Oct 06, 2008 | Palm TX Handheld
Palm Tx keeps short circuiting
Glad you have solved the issue. Let me know if it flakes out again.
-WN
Aug 28, 2008 | Palm TX Handheld
Deleting photos of my camera
Your camera creates folders on the SD card to hold the images. It puts about 100 images in each folder. (See page 111 in the User Guide.) When you erase images, it may only be erasing the images in one folder. But your computer still sees the images in the other folder(s). To completely erase all images, use the "Format" function (see pages 25 - 26 in the User Guide). To completely clear it, use the Low Level Format option. You can download the User Guide here.
Aug 27, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Palm TX Handheld Logo
201 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
