Question about Whirlpool Refrigerators
Wire! Where does it go? Whirlpool Refrigerator ET21PKXGW03
Green and Yellow Wire that looks like it should hook somewhere by the coils. But I don't know where it goes. Can someone help me.
4 Suggested Answers
oscarn
  • 110 Answers
SOURCE: Model ET14NKXEW00 Top freezer 1996 model Whirlpool refrigerator
Water from the melted evaporator frost is normally drained down to a pan mounted on the compressor . The heat from the compressor is normally enough to vaporize this water. Sometimes the evaporation may be reduced due to- high humidity (in the kitchen). Try keeping the exhaust fan on for a while. Also check if the drain line is blocked or shifted out of the drain pan.
Posted on Nov 20, 2008
Sea Breeze
  • 4654 Answers
SOURCE: whirpool et21pkxgw03 refrigerator
This is a common problem when the defrost condensate drain becomes blocked. Depending on the location of the blockage is the clue to how to prevent the blockage. Most times the blockage begins inside the freezer and overflows into the freezer creating a huge area of ice while at other times the blockage is just as it leaves the freezer and makes its turns going down to the pan below your refrigerator to reevaporate into the air inside your home. On the link below the whole page shows way of this happening and ways to stop it and resolve the problem. Read the entire page and use the part that most refers to you leaking problem. If you have further questions please contact me at appliancepartsse@yahoo.com, Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 24, 2009
caroldon
  • 17130 Answers
SOURCE: my whirlpool refrigerator/freezer is not
Switch off the fridge for few hours then before you you switch on check the continuity of the main power cord to the compressor which comes thrrough the main relay. Now the relay is activated by the thermostat/pressure switch/defrost timer.
So you will be able to trace the path of the power to activate the compressor. however if the relay clicks and shuts off the the capacitor must be checked or replaced. However if there is a heavy drain of current- use a clamp tester meter- the compresssor can be a suspect.
Please check this link for a idea of the parts.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
Posted on Sep 06, 2011
Testimonial: "very helpful...not looking good for my refrig!"
Whirlpool dryer M#gew9250pw1 need to know how to hook up ground on 3prong plug
when looking at the prongs on the plug ,the bottom pin is the earth/ground pin
if you look closely at the face of the plug ,there should be letters a for one pin ,n for another and e for the last pin
IN Australia the earth wire (E)is a yellow wire with a green trace on it,
red will be active (a)and black is neutral (N)
the earth wire goes from the plug pin to a metal part of the machine
If you have to ask then for safety sake maybe you should get an electrician in
May 25, 2015 | Whirlpool Dryers
There's a wire hanging down in back of the filter. don't know where it hooks to but think it has something to do with the temp. temp staying at 73 degrees. wire has yellow tip and look like it hook...
Hello, this is your temp sensor wire that leads to your thermostat. It engages and turns off the compressor, it should be mounted with a plastic mounting holder right on the evaporator coil behind the filter.
May 30, 2011 | Heating & Cooling
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
I am changing out the dryer cord on my Whirlpool electric dryer from a 3 prong to a 4. there is a green wire with a yellow strip coming from the dryer and grounded on the side of the dryer like a grounding...
Hello. Now that you are upgrading to the four prong you should unhook the green wire with yellow strip coming from the dryer and instead attach the extra green ground cord on the 4 prong to the screw on the side of the dryer. Regards, Joe.
If you prefer to see this in picture form, check this link: http://www.appliance411.com/links/jump.cgi?ID=466
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hooking up a tachometer in a '94 Ford Escort with Distributorless Ignition System
Check with your local autoparts store for a repair/maintence manual. the manual will have the wiring schematics for your car. good luck
May 02, 2009 | Computers & Internet
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Wire a ceiling light
is your house older, Some old wires its hard to tell which one is the grounded conductor(nuetral), Both Look black. If this is case You need to test it with a voltage tester- The green and yellow is a ground wire. Test the green with the voltage tester, Along with one of the blacks, if the Black and green set of the voltage tester that black is the hot. hook it up to the black on the lt. hook white to the other black. and green to either green screew or ground wire which ever is provided
Jan 07, 2009 | Electrical Supplies
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
