Question about Garden
Craftsman gas leafblower
After starting and running for a few minutes will stall when putting throttle to max and choke to minimum. Hi, I have a craftsman backpack blower model # 316.79499. I have a problem of the engine wanting to die when full throttle also, it seems as long as the gas tank is full it will run great, as soon as it gets down to about 3/4 full it starts to bog out. This happens even when the engine is fully warm. Any Ideas?
Thanks,
Karl
I just worked on my craftsman leaf blower that would only run at half choke. I tried cleaning the carb and also cleaned the exhaust port. Didn't help. Then i took the cover off and noticed that one of the head gasket bolts was loose. Tightened the head gasket bolts and then it ran fine. Must have been sucking some air.
Posted on Aug 01, 2010
  • 659 Answers
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Posted on Nov 18, 2008
  • Wesley Gardner
    Wesley Gardner Nov 18, 2008
    also make sure you have good spark on the unit as well. if the plug has been changed then make sure its gaping is correct or if its a old plug its always good to change it if need be.
2 Suggested Answers
  • 48 Answers
SOURCE: craftsman gas leafblower
All small engines take a few minutes to warm up...especially so as they age.
You have to learn to 'feather' the throttle to very, very slowly increase the gas.
After it is warmed up, you are much more likely able to rev it up...release, etc.
I've had many over the years, and this is a very common problem...that you learn how to handle.
Posted on Nov 06, 2008
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Nov 06, 2008 | Garden
Garden Logo
1,840 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
