Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Picture shrinking top & bottem
The picture seems to be bowed at the top and bottem of the screen. this makes convergence impossible to line up. Im a clinical engineer that does x-ray repair and other electronic medical equipment but tv is not my forte' is this a hv problem?
  • Zenith Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix ipicture shrinking top & bottem - 69189a5.pngw for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Posted on Aug 09, 2009
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
The picture shrinked and the colors are one on top of other
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some pics of convergence problems.
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Hitachi Televison & Video
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
Screen has a double image. looks like the green
Convergence is the problem. I just fixed my set myself with a kit from TvRepairKits.com
Nov 16, 2009 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 51S715 white grid lines are bowed at top and picture is now bowed also
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Jul 12, 2009 | Hitachi 43FDX01B TV
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9p5034c101 rear projection.chassis#ptv 835
Just replace the two STK392-110 Convergence ICs and that will correct the convergence. The small pic if its centerd in the center of the screen is usually caused by the opto-couplers being bad
May 18, 2008 | Philips 9P5034C 50" Rear Projection...
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
