Question about Sony STR-DE597 Receiver
The reciever keeps going into protection while in watching dvds.
I have changed all the wires and got new cords. This only happened when i got my new tv. 47" phillips 1080p
  • 27 Answers
Page 17 will tke care of it ...reset the Micro Prosseser...Otaa
Posted on Nov 21, 2008
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
Toshiba SD-6109c goes into protection mode as soon as I switch it on. I need a repair manual but cannot find one anywhere. Does anyone know the solution or where I can find a service manual. Please do...
Unplug all speakers rewire the speakers making sure not to cross anything check all wires for shorts (cat bites etc) Make sure that only 8 ohms (one speaker ) is on each wire or the ohms that are specified on the amp. In electronics 2 eight ohm speakers in parallel becomes 4 ohms total and will put the amp into protection mode. watch for stranded wire pieces crossing to the other wire. If it still has problems it may need to have the amplifier transistors/ics replaced. While the cabinet is open look for electrolytic capacitors that are bulged or split and replace them.
Nov 26, 2013 | Televison & Video
Rca rt2781h loosing sound
Hi. replace the hdmi cable with a new one..
Aug 04, 2013 | Audio Players & Recorders
Newly bought. cuts out. completey and seemingly
check all speaker wires for any frays or broken open places in the wire,,,cus newr recievers have a protection that does that if it shorts ,,to keep from messin it up,,change all speaker wires ,,also even though new dust will do that to,,blow out with a air compresser or something ,,goodluck
Nov 03, 2010 | Panasonic Audio Players & Recorders
When i turn power on it came on and says protect then turn off..please help
The reason why this is happening is because the reciever is going into protection mode due to a short circuit to the amplifier. It might be a speaker that is shorted out internally or there might be some speaker wires making contact with each other at the back of the reciever or at the speaker. The first thing I would do is disconnect all the speaker wires from the back of the reciever(make sure to label them before removing so you know how they go back). After removing the speaker wires turn on the reciever and see if it goes into protection mode. If it does then there is a good possibility that the internal amplifier might have a short. If it does not go into protection mode then that is good because there is more than likely a short on one of the speaker wires or speaker itself. Now connect one set of speaker wires at a time. After you connect each one try turning on the reciever until it goes into protection mode again. When it does you will have your culprit. Then try swapping speakers with that problem wire set and see if it still does it. If it does then it could just be the wires but also switch the wires to verify that the amplifier does not have a bad channel. If swapping both the wires and the speaker swapping produces the protection mode then that channel for the amplifier will be defective. I hope I have not confused you too much.
Aug 17, 2010 | Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
My stereo keeps saying ''protect''. how can i fix it? ive tried to unplug it for 4 hours and it still dont work
Check the speaker wire connections and make sure that none of them are crossed. Shorted wires will cause the reciever to turn on the protect mode to keep the amplifier from shorting out. Try disconnecting the speaker wires from the reciever. if you turn it on and it still says "protect" then the short is possibly in the reciever itself.
Nov 08, 2009 | Cars & Trucks
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Playing DVDs on Laptop through the TV
Here's what's happening... software companies like CyberLink subscribe to the Macrovision requirements for playing DVDs and protecting copyrighted materials.
Macrovision has approved numerous video cards for what they call "TV Out" which allows the movie to be displayed on your TV.
Unfortunately, your Dell Inspiron does not have a Macrovision approved and supported video card in it, so it gives instructions to the computer to disable TV Out and not allow it to play anywhere besides the computer.
Jan 06, 2009 | LG DRN-8080-B for Dell Inspiron Series DVD...
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
Sony STR-DE597 Receiver Logo
76 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
