Cannot re-connect Bose DVD player to HDTV
On installation DVD, after ''Reading'', next message is ''Format not supported''.
  • marina1836 Nov 29, 2008
    The DVD is the installation DVD - it does not appear to be damaged
    President:
  • 1,952 Answers
This problem to fix it is so simple it was hard to figure out...all you have to do is change the file name and add (.avi) to the end and your set.
You got the xvid source code from www.xvid.org. It’s useless unless you’re a programmer. Get the binaries from http://www.koepi.org instead.
it supports all formats, but if you read the above again
you will see they don't mention support for DVD+R (only DVD+RW). Is this
a typing error or does this drive not support DVD+R. Somebody told me
that with DVD devices you have to check very carefull in the specs if it
really supports all the formats and not to assume anything if it's not
in the specs, so therefore would like to know if anybody who has this
drive can confirm if this drive really doesn't support DVD+R
Posted on Nov 29, 2008
    Scholar:
  • 68 Answers
The format not supported is created from the TV, the particular connection choice you used is marked on the TV, one set of connections might be labeled: 480I only, 480I to 720P only.
There should be a couple choices of connections from the DVD player to the TV. This particular DISK is sending a signal that is either above or below the rated connection choice you selected.
generally if you have a component set of cables, [three colors video only], these are the connections that are problematic
Look to see if there is a s-video, or rca connection, my guess is that if you put another non hd disk in the player it would play.
write me at service@emrrepair.com, I have witnessed this situation many time, and it is always the input on the TV that is the issue.
Will
  • 10,594 Answers
What is model number of your Bose DVD player.
I think your DVD player can not play DivX format files so gives message ...format not supported.
  • Shahid Electronics
    Shahid Electronics Nov 30, 2008
    Can you give details about Installation DVD... like what you are going to install and where ?
  • 13,433 Answers
The format of the dvd inserted is not supported try another disc.
    Scholar:
  • 126 Answers
How are you connecting the DVD player? Did you change the region ID setting? Are you using a DVD-RW? Please post back.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest to reset everything or unplug from the mains both the Bosch DVD player as well as the TV unit. Unplug for say 30 minutes or so. Pls postback the model number of the Bosch DVD.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,550 Answers
Try with other DVDs .
That particular dvd might be damaged.
Unsupported format
I have the same problem. When I put in a dvd it tries to read it and then comes back unupported format. What does this mean and why won't it read the dvd?
May 05, 2010 | Bose 3 2 1 GSX System
Why is my dvd player saying 'format not supported? no matter what DVD I put it , it says the same thing....Format not supported...
Are you sure the dvd player is for usa dvd's and not foreign pal dvd's.
When did you purchase it and what is the make and model number.
Feb 15, 2010 | Bose 3 2 1 GSX System
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
DVD/CD constantly gives a ''format not supported'' messages and will not play
You have to make sure your device its compatible with the format of the fime, ussually expencive devices are not as compatible as the sheap ones. However yo can try to update your DVD go to your manufacture website and look for upgrades (availble for most DVD/CD player)
Nov 07, 2009 | Bose Lifestyle 28 System
My bose 321 system says format not supported when i try to play dvd
Could be dual layer DVD? Older players often won't run these. Try it on single layer DVD's. Some players won't run DVD's that have been burnt on a PC. If same message on DVD's that have played in the past, then have a look at player menu system - could need to be re-set up.
Jul 29, 2009 | Audio Players & Recorders
Hooking up dvd player to Toshiba DPL 52" HDTV
Send the viseo to the Tv using composite or component input and send the audio ( red and white RCA audio ) to the BOSE.
May 13, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Bose Lifestyle 38 can't read CD anymore...
some dvd player are unable to play burnt cds, does not support format, maybe your s.o.l
May 04, 2009 | Bose Lifestyle 38 System
Burned dvds wont play on home player
i have begun having a problem with my  4-5 year old bose 321 system.  sometimes dvd's burned on my computer will not  play on my bose 321 system.  sometimes they will.  what's up with this?  it's not a bad media problem.  i've narrowed it to the player.  sometimes i'll play a computer burned dvd on the bose and it will play fine.   next time i try to  play it it won't any ideas? thank you in advance mike
Dec 04, 2008 | Televison & Video
ERROR MESSAGE
maybe the DVD player you got is not supporting all DVDs from around the globe. There is this thing called NTSC region 1 for Americas, region 2 for Europe, Region 3 for Asia, Region 0 for everything. I don't know the other regions but that must have been the problem.
Dec 13, 2007 | Bose 3·2·1 II System
Bose Lifestyle 38 Unsupported Format message
All you have to do is carefully take the top off and clean the "Iris" which is the reader with a little alcohol and cotton swab. Bose will charge $165 plus shipping to do this. Go to website metacafe.com and search how to clean DVD players and it will show a video, easy to understand.
Nov 10, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
