Question about HP Pavilion dv6000z Notebook
Problem with touchpad
My hp laptop with vista ultimate OS is undergoing a problem.The touch pad is not working.The movement of the cursor is monitored by it but the click process is not functioning.None of the folder or icon is opening by the click although the cursor is moving.
  • 903 Answers
If you have a usb mouse try plugging this in and see if it works opening your files etc.... if it does then do to control panel>system>device manager and and look for pointing devices, right click on touchpad and select uninstall. Reboot your computer and remove the usb mouse, windows will pick up your touchpad as new hardware and install it. Hopefully this will resolve your problem
I hope this helps
Posted on Nov 16, 2008
While typing cursor jumps of to different lines and different areas
If you are using the touch pad, try turn it off and using an USB mouse. I have found that my palm hits the touch pad and causes random cursor movements.
May 12, 2011 | HP Pavilion dv4000 Notebook
The cursor keeps jumping when typing, how do I stop it
even slight hovering over touchpad may do this if touchpad is not disabled automatically when you type. disable your touch pad or look for the setting in bios
Nov 13, 2010 | Microsoft Windows Vista Ultimate Edition
I'll move the cursor to one spot on the desktop and it will move itself to another....windows 7
You mean, the cursor is erratic and moving all around here and there?
Decrease the Touchpad Sensitivity...
I see that your Laptop was shipped with Windows Vista and it seems you are using a Retail version of Windows 7. Specially, HP/Compaq Laptops is designed for Retail versions and you can face some device/driver functionality issues. But, you can still try the followings.
As per my knowledge, your Laptop has the Synaptics Toucpad.
To Change the Sensitivity of the Touchpad:
1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
2. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings. In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
3. Select the PalmCheck option to adjust the sensitivity (decrease it) of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
If the Device Setting tab is missing.....
1. Click Start, in the Start search field type Msconfig and press enter.
"System Configuration Utility" box will pop up on the screen.
2. Click the Startup tab.
3. Search for "Syntpenh" entry and select the checkbox beside it.
5. Click OK. Restart the computer. Perform above step.
If you are still not able to perform the steps, update the driver from following link.
Synaptics TouchPad Driver: ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44969.exe
Restart the Notebook and check for the problem. It should be resolved now.
Aug 22, 2010 | HP Pavilion dv9000z Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Same problem with acer travelmate 4060
I have seen this too many times. Make sure your touch pad and hand is clean. Any moisture like sweat will cause wacky movement. Dry and grease free for best results.
You may want to update your driver to the latest for your OS here.
http://www.synaptics.com/support/drivers
Sep 06, 2009 | Acer Computers & Internet
Touch pad isstP Pavilion cursor starts drifting uncontrollably
try removing your battery and replace it back. its like resetting it.
May 16, 2009 | HP Pavilion dv4000 Notebook
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
No cursor control
U may have to reinstall ur touch pad driver
otherwise use external mouse and then check it out
otherwise uninstall ur touchpad drivers then install it
Jan 20, 2009 | HP Pavilion dv6000z Notebook
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
HP Pavilion dv6000z Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
