Question about Jensen VM9510 Car DVD Player
When trying to listen to radio with the car speakers and DVD in rear of vehicle (headrest monitors) by using headsets, there is no sound in headsets.
  • 944 Answers
Here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
Posted on Mar 10, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 11, 2007
    Sorry was a bad link should be:
    http://www.audiovox.com/
    Click on Jensen, select multimedia, then select "older models" and half way down you will find the link to the manual.
    It sounds like you may have a problem with the audio settings, or equally likely that the wiring was not completed when the unit was installed - did the headphones ever work? - if so - also suspect the wiring, probably where the cabling from the unit is connected to the car's system.
    Hope this helps more :)
INSTALL JENSEN RADIO vm9511ts
There should be a label with all the wiring on the player/radio itself.
Yellow goes directly to battery to hold memory
Red is for ignition switch to power on
Black is ground
Blue is not used unless you are power an amp or other accessory.
All other wires are for speaker wires.
You can get a quick connect harness so you don't have to cut your factor vehicle wiring. If you did do this already, you can go to installer.com to find out which wire is for what.
Sep 23, 2009 | Jensen VM9510 Car DVD Player
Why dont i have a picture in my headrest monitors
are you hooked on the right output from the indash??
do your headrests have more than one input option??
or do they ever just say "no signal"
check that out maybe something got overlooked
Jun 23, 2009 | Jensen VM9510 Car DVD Player
I hook up my jensen and i'm not geting no power
check the fuzes on the radio and on the car.  You may have tapped into a wire that turns off with the key
Mar 11, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9510ts
my jensen vm9510 ts turns on and you can listen the radio dvd's cd's but the screen do not come out even if you reset it and press the open button, so you can't seen anything is already coded to play dvd's with out eh parking brake. If any one can help me please.
May 07, 2008 | Jensen VM9510 Car DVD Player
Jensen vm 9412
Does yours give of a static noise coming from the speakers?
Jan 19, 2008 | Jensen VM9510 Car DVD Player
try each of the four speakers independently. It's likely that ONE is blown (or has a wire shorted to ground) and is causing the unit to shut down.
Sep 11, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9132 07' model
At audiovox.com has some upgrade files for the jensen vm9312 that is supposed to fix this problem. First you have to find the vm9312 and then click on software updates. Audiovox makes Jensen products i believe.
May 12, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
219 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
