Question about Logitech V250 (9675380403) Mouse
Wireless mouse/ keyboard will not work when 2nd computer is on
Wireless mouse/ keyboard stops working the instant i turn on a 2nd computer. my 2nd computer does not have a wireless mouse/ keyboard. both computers run off a wireless router in my basement. new computer windows xp , older computer widows nt 2000. wireless key board is a belkin
  • 258 Answers
There must be interference on the signal from the mouse by the second PC
Make sure that there are no power cables close to the mouse or receiver, I have seen this cause problems many times.
You could also try changing the channel in the router settings in case this is causing the problem, it may be on the same channel as the mouse but only interferring when the second PC is turned on, ta, HPC
Posted on Feb 21, 2009
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
My DEll mouse stops working when it feel like it. have to shut computer off and turn back on for mouse to light and work for awhile again. What"s wrong?wrong
Try your mouse in different USB ports, if it works well in the other ports then you know your original port is bad. If the mouse still acts up, then go ahead and try another usb mouse in the computer. If the 2nd mouse is working then you know the original mouse is bad. If the 2nd mouse is not working then you know that the usb ports on your motherboard are bad.
May 17, 2010 | Dell U0636 Mouse
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My wireless mouse stopped working. I've changed
there should be a connect button on the bottom of the mouse, if that doesnt work try removing and reinserting the usb receiver on the computer itself.
Dec 21, 2009 | Computers & Internet
Wireless mouse stopped working.
Unplug the wireless receiver from the back of the computer. Wait 10 seconds and replug back in. Check connectivity. If nothing then check batteries in mouse, if still nothing try click the Connect button on the wireless receiever and then underneath the keyboard...repaet the process for the mouse. You should get something on the screen stating the channel 1 is for the keyboard and channel 2 is for the mouse. Hope this helps! - Erick :-)
Dec 19, 2009 | Microsoft Wireless Laser Desktop 4000...
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My logitech wireless mouse works but the wireless keyboard does not. When I try connecting the keyboard the mouse stops working. I can get the mouse working but can't get the keyboard working. The only key...
The keyboard is not recognized by your PC. By the way, do you have the software installer for your keyboard.? Run the installer in your PC, and try again
if it now recognize the keyboard.
Sep 24, 2009 | Logitech Wireless Access Duo Optical...
Can't get cordless mouse and keyboard both working. Can only connect one or the other.
disconnect the small wireless dongle from the back of your computer..reboot the computer..put it back in,,and then press the connect button on bothe mouse and the keyboard to check,,the battery of teh mouse and the keyboard shud be checked if possible
May 08, 2009 | Logitech Wireless Access Duo Optical...
Wireless Mouse Just Stopped Working
Press the connect button on the reciever and then the connect button under the mouse for the computer to recognise it again.
Hope this helps
Nov 01, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Oct 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech V250 (9675380403) Mouse Logo
98 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
