Question about Motorola Mobility H350 Wireless Headset
Connecting motorola headset h350 to T-mobile motorola phone
I'm trying to program this bluetooth headset to my phone.
  • Lou Labetti
    Lou Labetti May 11, 2010
    What type of phone?
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
I have two Bluetooth-enabled devices from Motorola: (1) DECT cordless phone (B802) and (2) headset (H790). They are paired. I can use the headset to answer calls, however, I can't make headset to work when...
If this is happening while the headset is connected either the Motorola or DECT, then there's a problem with the small circuit board or the program of the headset. Small electronic devices have their program called the firmware.
BUT first, try using another Bluetooth headset and connect it to both phones (one at a time) and then test it with outgoing call. If it does work, then the problem is isolated with your problem headset.
For this kind of problem, you need to contact the manufacturer of your headset for repair.
Good luck and have a great day!
Jan 13, 2010 | Cell Phones
I cant program my bluetooth to my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 27, 2009 | Panasonic BLUETOOTH HANDS FREE KIT...
Need to program sprint bluuettoth headset compatibable to v2.o
turn the bluetooth on, on the device .. then place the headset in pairing mode, search for the device from the phone then place them a foot apart once it finds the headset name it and it will ask for a code it is normally 0000.. then it will say device is paired and it will work
Aug 27, 2009 | LG enV VX9900 Cellular Phone
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Programming bluetooth wireless head set model PBH-8W
If you need a copy of the instruction page, I can send you a pdf. ss061092@yahoo.com
Pairing your headset and cellular telephone:
1. Ensure that the headset is off.
2. Press and hold the multifunction button until the indicator light
turns on in blue (approx.8 seconds).
3. Set your Bluetooth-Compatible Phone to discover the headset by
following your phone's guide.
4. Typically, the steps involve going to a "setup"connect" or
"Bluetooth" menu option on your phone.
5. Select the option to locate, find or discover Bluetooth devices.
6. Press and hold the multifunction button on the Wireless Headset
until your cellular phone locates the device.
7.Your phone will find "-PBH-8W" and ask if you want to pair with it.
Confirm by pressing Yes or OK.
8.Your phone may ask for the password to the headset. Enter
"0000" (four zeros) for the code or passkey
9.Your wireless device will operate up to 30 feet from the wireless
telephone.
TECHNICAL ASSISTANCE:
Contact GNBI: GnbiTech@aol.com
Telephone
# 1-800-541-GNBI (4624)
Reference # PBH-8W
Sep 13, 2008 | Cell Phones
Bluetooth
I have a LG rumor phone from sprint and I am trying to program my bluetooth samsung WEP 200 and it is saying no bluetooth device found how do I set up the bluetooth I lost my instruction. The bluetooth was previously hooked up to the Razor phone
Sep 11, 2008 | Samsung WEP200 Headset
BT160 connect problems
while your in the phones bluetooth manager/program and searching for the device. press the bluetooths buttons to enable the 2 to syncronise. if you press the up/down volume buttons while searching with the phone, it should find it, and syncronise. by pressing different buttons, your giving the phone a chance to detect a bluetooth signal change, and receive the device.
Mike @ compurepair.
Apr 01, 2008 | Jabra COMMUNICATIONS BT160 Bluetooth...
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Motorola Mobility H350 Wireless Headset Logo
116 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
