Question about Apple Power Mac G4 Desktop
CD drive window does not open
I just got an used G4 mirror door. I opened the CD drive door by pressing in the middle joint. But the CD holder does not op[en. How do I open it to insert a CD?
ChanSt. Louis
  • cmahanta Nov 16, 2008
    Thanks much. I have since figured out how to open it.
    Now the next question is about how to open the lower drive. Is it a Zip drive?
    Thanks.
    Chan
    No, there is no disk in it. When I open the mirrored lower lid, all I see inside is a fixed metal plate.
    Does it perhaps mean that the machine does not have a reader in the lower slot? My older G4 ( 400 mHz) had a zip drive in the lower slot.
  • 33 Answers
When you are booting press and hold mouse button downthis should eject the drive have you tried this yet?
Posted on Nov 16, 2008
  • thejohnsonsn Nov 16, 2008
    is there a disk in it ???
    if there is a metal plate then yes there is NO other drive in the unit
My passenger side front and rear windows,locks and mirror controls dont work
the window control and mirror those wire goes truth the driver door if you open the rubber in the middle of the door wire always get damaged there its when the door is open many time wire move and snap inside that black flexible rubber you have to open that rubber and repair those wire thank for using fixya
Mar 01, 2011 | 2004 Jeep Grand Cherokee
How to install 2006 xA driver side mirror?
just the mirror or the entire housing ???
just mirror
  • remove old mirror (pry out)
  • unscrew from holder
  • screw new mirror into holder
  • press holder back into housing
entire housing
  • open door
  • pry off mirror shield (might need to unscrew) the shield is inside the door which hides the bolts holding the housing
  • unscrew housing
  • remove power cable (if any)
  • plug in cable to new housing (if any)
  • bolt the new housing in place
  • replace shield.
Sep 14, 2010 | 2006 Scion xA
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
How to program the suv morano garage opener
1. Press and hold the two outside garage opener buttons located on rear view mirror until the red LED light blinks (could be 20 sec.)
2. Press and hold the middle button on the rear view mirror while holding a garage door remote 1-3 inches away from the mirror and pressing the remote button. Do this until the blinking LED gets noticeably faster.
3. Once programmed - use the garage door opener on the mirror thru 3 cycles or more to verify.
Jun 26, 2009 | 2005 Nissan Murano
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Can open cd tray. How do you open zip drive on G4 Quicksilver
please see on cd drive u seen 1 small hole insert small stick in open tray .
Apr 28, 2009 | Computers & Internet
Laptop dvd drive door will not open
update the firm ware for this drive if that is possible. This will rewrite the eprom data and hopefully restore lost functionality.
Feb 11, 2008 | Computers & Internet
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
Drive door will not open nor will it play
To open the drive door this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down) 3)Tap gently, yet briskly at the joint where the plastic faceplate connects with the metal top of the unitat the area situated around the middle of the dvd tray (area in the attached pic, that the red arrow points to)
Mar 09, 2007 | Philips DVP642 DVD Player
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Apple Power Mac G4 Desktop Logo
171 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
