Question about NAD T763 Receiver
NAD T763 shutting down in certain modes
When listening to channel music (in DVD mode) or satellite TV, the sound from my front speakers shuts off and I have to turn the reciever off and back on again to get sound again. I am using a seperate 2channel amp to power my mains, and I had that unit serviced to make sure it was OK after a problem with one of my speakers. The receiver does just fine when in 7.1 EXT surround mode and plays all night with not a hint of problem. It only shuts down when in 2 channel mode. On two occasions, it also froze up and would not respond to remote control commands or by pushing buttons on the unit directly. NAD technical support had me do a factory reset, but the problem persists. I need to know if it is a receiver problem or an amp problem. I am fairly certain it is the receiver, but am looking for a second opinion. Also, switching from one "mode" (DVD, Satellite,EXT 7.1) there is an audible "thump" from my front speakers. Please help!
5 Suggested Answers
SOURCE:
SOURCE: Right surround channel not working in some modes
I had the same problem with the right channel.    It turned out to be a broken wire inside the receiver; it can be found connecting from the main PCB to the card for the 5.1 board.    After repairing the broken wire, it has worked fine.
The harness connects the 5.1 low level signals to the board which are then redistributed to the amplifier section.     It is a bundle of wires in gray casing and with red, black and white wires (with shielding).
Find the offending wire, repair or replace and it should be fixed.
Hope this helps
Posted on Oct 27, 2007
  • 79 Answers
SOURCE: NAD T763 - i turned it on and all the lights on
Have you tried doing a factory reset?
1. With unit powered ON, press the VIDEO and TONE DEFEAT buttons.
2. Display will show "AH RESET DONE".
3. Power off (from rear panel switch) and back on.
Posted on Jan 29, 2011
dunnbiker
  • 8546 Answers
SOURCE: NAD T-763 receiver. cannot get
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Posted on Apr 20, 2011
henrikspc
SOURCE: How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
Posted on Dec 17, 2012
Am using a Samsung HT-e750W ampiflier. When i play a dvd i can hear the music but no vocal sounds
The vocals are directed to the centre channel. If this is not connected or the connection is poor then it will mute the sound of the vocals.
If you want you can select stereo mode when listening to just music. Not the surround modes. Or you can check the centre channel is working and not switched off. Some amps have the ability to switch speakers off in different modes or settings.
May 12, 2018 | Samsung Audio Players & Recorders
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Apr 19, 2011 | NAD T763 Receiver
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Jan 29, 2009 | NAD T753 Receiver
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Shutdown during exciting audio
check the wattage of the speakers, they could be drawing too many watts from your amplifier, if you plug in a speaker that's more than the channel, it could harm your amp.
for example a 200 watt stereo, with 4 channels that equals 50 watts per speaker.
Hope this helps you out
Apr 01, 2008 | Audio Players & Recorders
Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Aug 30, 2007 | Onkyo TX-DS474 Receiver
Volume and multi channel output issue
Hi there. Are you familiar with board level repair for such products ? Your problem is most likely hardware. Either some of the final output transistors are fried, or it's a dsp problem, a regulator, a diode, a transistor in the circuit.. it could be a lot of things. But if everything was working fine and it quit someday without a change in the system's setup, it really looks like an hardware issue ! Do you have a way in the manual, that sets factory defaults, a kind of reset ? A lot of such units do have that. Try to unplug/interchange speakers as well, a shorted speaker could make the amp go nuts as well, but i wouldn't bet on it. Still, i'd check that out. Hope that helps ! cheebster.
Jun 26, 2007 | NAD T763 Receiver
NAD T763 Receiver Logo
127 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
