Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
Hot water on cold side when first turned on moen 7600 series
When you turn the cold water on you get a shot of cold then hot water until you let it run awhile this happens almost every time you use the sink. single handle kitchen faucet
  • 2 more comments
  • mikezar1 Jan 29, 2009
    did not change anything just started to be this way if I turn water on with handle on cold side you get cold water then it turns hot water for about a quart or so then back to cold water
  • marty metzger May 11, 2010
    did you ever change cartridge. moen will send you one for free in a few days.
    no need to take catridge out or turn off water. just rotate stem 180 degrees
  • Anonymous Mar 12, 2014
    Low water pressure in a Moen 7700 series single handle kitchen sink
    Genius:
  • 1,605 Answers
Did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Posted on Nov 18, 2008
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
The faucet I am having trouble with is a single lever, kithen faucet. It is a Moen PureTouch faucet with water filter in wand. The cold water works fine no matter what on either cold side or hot when the...
This needs a new cartridge and may only cost you a couple of bucks at your local plumbing store. If you do this yourself, just make sure you turn off the water to both the cold and the hot and you will probably just need a allen wrench, screw driver and maybe a cresent wrench.
Aug 03, 2009 | Moen Plumbing
Hot water faucet turns wrong direction
You have a cold side valve part assembly in a hot side. Order for free@
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 03, 2009 | Moen Plumbing
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
573 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
