Question about HP Computers & Internet
I have a new HP 9430 desktop. When left running it will cycle down to a dormant state but the fan is running continually and it won't come back unless I pull the power and restart
    Sergeant:
  • 207 Answers
What I believe is your problem is that your computer is going into a power saving mode called a "Sleep state".
If this is the case you should be able to "wake it up" by pressing the sleep button.
HP/Compaq usually put one on their keyboards. It has an icon on it the shape of a crescent moon and is usually labeled "Sleep" Press that to give your pc a wakeup call when it is asleep. Or if you want to put your PC to sleep to save power when it is awake.
If your like me you probably don't care for this feature. Fortunately it CAN be disabled easily. open the page you would use to change your screensaver. At the bottom of it is a smaller page with an "Energy star" logo in it.
This is your power settings control panel. From here you can adjust the settings so the "Sleep state" takes longer to kick in or disable it altogether.
You should also be able to find power settings in the control panel (But the path is different depending on which version of Windows you have" but it is always at the bottom of the screensaver panel.
Good luck
Dave
Posted on Nov 16, 2008
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
Computer just shut down and won`t boot back up
You could have an overheating problemWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 24, 2012 | HP Pavilion a1600n (882780776265) PC...
Windows xp copies files but won't install, keeps looping setup
When it runs the first time and it restarts. It will display PRESS ANY KEY TO INSTALL FROM CD\DVD..... Don't press anything. It will continue from where it left off. Cheers.
Jul 26, 2011 | HP Pavilion 522n PC Desktop
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
I NEED A NEW FAN FOR MY PC. HP:IQ700 PART#GC125025VH-A SUNON BRAND. CAN'T FIND ONE TO BUY.......
does not need to be exact model / mfg as new.
purchase any fan same size and speed/application that fits.
Apr 09, 2010 | HP TouchSmart IQ770 PC Desktop
When i turn on computer on/off button just flashes constantly and computer does not come on
Probably a problem with the power module. Unplug it and lit is sit for a while then plug it in and see if it corrects the problem. If not just look at the back of the computer.
where the power cord enters,and see if the fan is going.
if there is any unlit led there. If it is unlit.
Or if the fan is not going., you may need a new power unit.
Remember that most computers have more than one fans. Look for the fan that cools the power unit, Not the one that cools the CPU or video cards.
They are lower down. and since these fans fan does not always have to run continually.,.
Jan 16, 2010 | HP Pavilion a1610n PC Desktop
57.03 error
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
HP home computer will not turn on
i guess the problem is there in the power supply i.e, smps of your cpu. change it and check whether it turns on. if your pc fails to start after changing a new smps then the problem should be your motherboard.
Jun 18, 2009 | E-Machines eMachines Desktop PC
Pc sht down stating thermal error. suppose processr fan not working. can this be the cause of the eror?
Most of the time you'll never hear the CPU fan. If you don't hear the normal fan sounds coming from your computer, it is most likely the power supply cooling fan. Hold you hand at the back of the computer where the power chord plugs in, while the computer is running, and test if you feel air blowing on your hand. If you don't, then replace your power supply. Make sure, when checking for a new PS that you get the correct pin count. Best to order from Dell since proprietary systems usually use proprietary parts and a generic PS won't fit in the opening at the back of the computer (alignment of the plug and the fan with the opening, etc.)
May 25, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
